Question about Canon EOS 450D Digital Camera
My ES6000 camcorder has a sticky surface - How can it stop?
My Digital ES6000 camcorder has had instances in the past of having to endure a somewhat warm environment from time to time in the past due to A/C problems in my home. I just got it out and it has a very sticky almost soft texture on all the soft grip surrounding the camera. How can I get it to stop being sticky? Is it safe to wash with a bit of soapy water? The sticky texture also leaves a stain on my hands. I sure would like to reverse and stop the stickyness. Please help. This was a very nice Hi8mm Camcorder.
    Brigadier General:
  • 11,967 Answers
Try wiping it with a cloth dampened either with Windex or a 50/50 mix of vinegar and water.
Posted on May 10, 2010
How do you clean the sticky speaker cover on an iPod dock speaker?
the material of which it is made has come into contact with a solvent ( fly spray, hair spray,cleaner agent, nail polish remover ) and the molecular structure is breaking down
it will be difficult to stop the stickiness as you will have to seal the surface first
Jun 25, 2016 | Altec Lansing T612 Digital Speaker for...
Oster wine opener sticky rubber surface
Did anyone have an answer to this? I have had the same problem. I like the opener, but the parts of the rubber surface that are not usually handled get quite sticky. Any thoughts on preventing this, or if not on removing the stickiness?
Jan 04, 2013 | Sunbeam Oster Electric Wine Bottle Opener
How to unlock samsung bd-es6000 DVD Region
Switch on without DVD
Press REPEAT button on the remote
Press 53814 and you should see number 5 on the top right corner - immediately press 9 (you might have to do this twice)
Switch off this sould make ur player region free.
Thanks
Jun 16, 2012 | Televison & Video
My hyundai gets dashboard has started getting sticky (melting) , please advise solution
sounds like someone used solvent cleaner...only thing you can do is clean fresh water and vinyl cleaner.if it turns grey then you may have to use vinyl paint to get it back to its original finish.
Oct 14, 2010 | Hyundai Accent Cars & Trucks
Sony hc-32 touch screen won't work
When touch switches become nonworking then mostly its cause of connecting flexible ribbon wires between LCD board and camcorder main board that got cracked so touch buttons signal does not go to camcorder system control. Need to replace that flexible wire by qualified camera tech.
Very rare cases I found touch buttons layer that is pasted and part of LCD becomes defective, do you see hard or deep scratch on LCD surface? if yes, then LCD screen will be replaced because touch button array is damaged.
Thanks.
Sep 16, 2009 | Sony DCR-HC32E DV Digital Camcorder
DVD surface layer damaged
If surface gets "yucked" up the laser mechanism cannot see or read the data encoded on its surface. Try cleaning the surface with a wet paste made of baking soda and scrub it in good. It cleans without scratching the plastic surface coating. You have to get rid of the surface film that is causing the issue without scratching the plastic. Good luck!
Sep 02, 2017 | Televison & Video
Panasonic NVGS4 camcorder problem
Did you try with different tapes? light turr sound is always there in Rew/FF as the tape rotatets very fast. If the head motor stops while spinning, the error will be detected and the unit needs resetting. also if the head is sticky, tape gets stuck on head and unit will stop. Try to clean the head with head cleaner and check.
Feb 27, 2007 | Panasonic NV-GS40 Mini DV Digital...
Flashing light
Im not sure what your intermittant problem is But these camcorders and its almost every make that I know of, unless they stopped using them. Im talking about the small surface mounted panasonic capacitors that they have used for ever in camcorders and other smaller devices. They are called Pan. Caps and after a couple of years , they start to leak and make all sorts of complaints and problems, and after a while will even ruin the Printed circuit Boards as the chemicals inside the caps leak out and literally eat up the Printed circuit board traces. In a case like that the printed circuit boards have to be replace. In the past I did alot of the older sony analog and some digital camcorders and I had one camcorder I will never forget as it had 6 differant complaints , from veiwfinder to color to recording ,sound problems ect. I found a total of 58 bad capacitors in that puppy. I have also worked on several that had a really bad smell to them, and from experience you know that Printed circuit board is shot. Any sign of troubles and the camcorder should be taken into the repair shop asap. Also after not using a camcorder for a long period of time is when you will probably have most of your problems. Good Luck
Jun 12, 2006 | Panasonic NV-DS29B Mini DV Digital...
Why should I record my memories on a Hitachi DVD Camcorder?
The picture and sound quality of footage stored on a DVD does not degrade over time. Home movies can be shared with friends and family decades into the future in perfect and pristine condition. Motion video stored on a 8 cm (3 inch) DVD-R disc can be played back on most DVD players and compatible PC DVD drives. After finalizing the DVD-R disc in the camcorder, it can be placed directly into your home DVD player and played back. No additional adapters are necessary and you do not have to connect the camcorder to the television. With DVD, you can instantly access desired scenes without having to endure the time consuming task of fast-forwarding or rewinding. Through Hitachi’s Disc Navigation feature, you simply select the thumbnail image of your favorite scene and it begins to play immediately. 2005 Hitachi DVD Camcorders support four different types of recording media. For motion video you have the option of using a 8 cm (3 inch) DVD-R disc or a 8 cm (3 inch) DVD-RAM disc. Digital still photos can be stored on DVD-RAM discs, Secure Digital cards or MultiMedia Cards. Size Hitachi introduced the world’s first DVD based camcorder three years ago. Since then, Hitachi engineers have been able to perfect the technology and to reduce the physical mass of the camcorder by 45% making it the most portable DVD camcorder in the industry.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Canon EOS 450D  Digital Camera Logo
146 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
