Question about HP Laserjet M2727nf Multifunction Printer
After I turn it on it shows an error messaje
After I turn it on it shows an error messaje that say "scanner error 5 turn off then turn on" but after I turn it back on it display the same thing and when I try to make a copy or to scan a document the screen shows "device is busy try again later" I don't know what's wrong with it, can you help me to solve this problem please? I will really apreciate it Thankyou.
    Sergeant:
  • 253 Answers
There are problem in scanner assembly. please clean care fully and properly of your scaner unit.,than its ok.,
Posted on May 10, 2010
Solving scanner error 5
If you are using windows - go to Printers / Devices and uninstall the printer
Turn the printer off and wait a couple of minutes
Now turn on the printer
Now add the printer in windows again and it should work
Jun 30, 2017 | The Office Equipment & Supplies
Mi camera digital Nikon D 60 got a messaje: ERROR PRESS SHUTTER RELEASE BUTTON AGAIN Cant anyvary help me to fix it
It is nothing to lose to try this:
1. Remove the battery (the charged and good working battery),
2. Switch the power to ON position,
3. Press the shutter button for 5 seconds.
4. Switch the power to OFF position,
5. Insert the battery,
6. Switch the power to ON position,
7. Try to take a picture.
Please post the result here.
Mar 03, 2014 | Cameras
When startup show the messaje "WARNING DEW DETECTED" and 5 seconds later shutdown
Dew warning is normal and means condensation has been detected the camera. Usually this happens when you take the camera from a warm room to a cold external place or vice versa. Wait for about an hour or so for the camera to acclimatise.
Apr 27, 2011 | Panasonic PV-L550 VHS-C Analog Camcorder
Its showing scanner error 8 and 5
Hello, this indicates aproblem with the copier scanner assembly.
For more information follow the posted link.
Scanner Error 5 CLICKHERE
Feb 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have problem to my printer showing Scanner Error 5 turn off then on please need help
You need a tech to check out or replace the scanner. It might be something simple, like a loose wire harness, or just a bad flatbed scanner assembly. Most likely an error code 5 is the the connector with the 2 blue wires over the formatter. Try reseating it. You didn't say what kind of printer you have. So this is just guess work.
Aug 07, 2010 | Office Equipment & Supplies
HP m2727nf scanner error 5
Hi Anataloi,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp 1800-334-5144 , if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Jun 25, 2010 | HP Laserjet M2727nf Multifunction Printer
Hp laserjet3030 is put on it shows" Scanner Error"
Hi ritaccpl: Here is your problem. 52 Scanner Error The all-in-one has experienced an internal hardware error. 1. Turn off the power by using the power switch, and then wait at least 30 seconds. 2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket. 3. Check the FFC connection between the formatter and the scanner. NOTE Do not bend or fold the FFCs during the removal or reinstallation process. 4. Try connecting the product to a different power source or surge protector. 5. Turn on the power and wait for the all-inone to initialize. 6. If the error persists, replace the laser scanner assembly. Hope this helps
Jun 08, 2009 | HP LaserJet 3030 All-In-One Printer
HP M1522nf printer, shows "scanner error 5"
I have the same problem, could you pl let me know where can I get the stepper motor?
Dec 08, 2008 | Office Equipment & Supplies
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP Laserjet M2727nf Multifunction Printer Logo
355 people viewed this question
Seeker5211
Seeker5211
