Question about Ricoh Aficio 450 Copier
Code SC 547 00
What is this code and how do we clear the open door symbol and the tool symbol so that the copier will start up?
  • quilt Mar 28, 2008
    The copier is a Ricoh Aficio 340 and the screen said SC 547 00
    We can't use your Premium Assistance plan. We don't have a credit card and live 100's of miles from shops etc.
    Hope you can help, thanks
  • quilt Apr 01, 2008
    Our apologies for the delay in replying to you. Thank you so much your advice was spot on and the problem is fixed!
    We are most impressed with the service you provide and will certainly recommend you to others!
    Kind regards
    Quilt
  • 87 Answers
SC 547 is a fuser problem. Press clear modes, 1, 0, 7, and press and hold clear/stop/ Enter copy sp. Select 5 for mode. exit all of the way out, and recycle the power. If something in the fuser is bad, it will do it again. If it comes to ready, then the thermister is probably dirty. As for the door, make sure all are closed tight, including the lower right door.
Posted on Mar 28, 2008
SOURCE:
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press 1 , 0 , 7
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
ENG:prcon.c
Turn ON the copier ,enter in SP mode as follows:
Press the mode/clear(yellow)key
enter "107"
press the clear/stop (red) key for more than 4 seconds
Touch SP mode on the display
Open the front cover
Turn OFF the copier
Wait 3 minutes
Closed the front door
Turn ON the copier.
This error code appaires when using for use OPC drum and not original genuine Ricoh parts(Katun and other brands)
Feb 14, 2013 | Ricoh Aficio 2035 Copier
Sc542
Press Clear(yellow)key then press 107 press and hold Stop/Clear(red) key more than 3 second select SP modes,open a front door,turn off the power switch,wait 2 minutes,close the front door and turn ON the copier.
SC 541-542 fuser unit thermistors or thermofuses malfunctions.
Jan 22, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Please describe your MALFUNCTIONING CODE C 1200 OF bizhub 8031 copier problem:
Clear the trouble code with the following procedure:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch.
3. The code should clear and a message to close the front door should appear
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 13, 2011 | Minolta BIZHUBC351 Color Copier
Ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Dec 28, 2009 | Ricoh Aficio 1035 Copier
Ricoh 1035. The moment you turn the photocopier on it reports error code SC560 suggesting i should call service agent or the supplier. what could that be please???
Enter in the service mode Yellow key-107-red key,enter in the SP mode open the front door,turn off the copier,unplugged,wait 10 sec.,pluged on close the front door and turn on the power switch.
Nov 08, 2009 | Ricoh Aficio 1035 Copier
Copier will not operate
Have you attemped to open close the front door? Also check all doors that open
Mar 25, 2009 | Minolta Office Equipment & Supplies
Ricoh Aficio340
Well, you sound like you figured out part of your problem. If the open door symbol is showing, then you need to find out which door the machine thinks its still open.
Check all the doors, front, both right and left doors, and if the machine has a bottom console, then check those doors also.
I would open every door and reclose them again and see if you can get the DOOR OPEN symbol to go away. Need to start with the basic first.
Once this is cleared then we can see if we can troubleshoot any other problems.
(Most doors have a little stub that sticks out that either goes in between a sensor, or pushes on a switch to tell the machine that the door is closed.
If after opening and closing each door, and the machine still says Door open, then Next step I would take is to see if there are any places on the door that looks like a small piece of plastic might have broken off.
Let me know what you find.
Good luck.
Mac
Mar 29, 2008 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
600 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
