The red lightstays on. if i shut off and turn back on the lights start to reset, within a second or two the rollers i think jam and the red light comes back on. i can find no paper jam. printer continues not to operate. i've opened all know places to look for a jam.
pulling the paper out can damage the roller feeder. also make the roller out of sync with the other rollers, i think to reset it you will need to activate ink cartridge change this can some times sort out the problem. remove the cartridges and leave out it will reset and say not inc. when it does this put the inc back in and it should reset.
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
The red light on this printer would normally indicate paper jam, a cover open or the waste toner container is full. I would recommend double checking that no small bits of paper have got themselves lodged around rollers inside the printer. Failing this I would check the status of the waste toner bottle to see how full the printer thinks it is. This can normally be done using the printers software on the PC, but sadly I am unfamiliar with doing it for your particular machine.
The most probable solution is a new motor, but you may get lucky. I would first make sure that there isn.t something that fell down the filter hole and is caught in the blower blade. Possibly the rollers are jammed and won't let the drum go, but usually when it groans and won't go it is the motor
If your ps3 doesnt turn on at all and its just a red light. You need a new internal power supply. If the ps3 turns on for just a few seconds and beeps you need to reflow your cpu and gpu on the motherboard. You have yellow light of death.
try reseting your video settings by holding the on;off button for about 5 seconds when turning on . if this doesn't work, must be a problem with your hardware. then you should take the system to a support centre.
about the disk, have u tried to turn the system on by pushing directly the eject button ?
is your printer dirty? check the rollers on the back of the printer and the top and make sure the rollers are clean..also check for paper thta may be stuck in rollers or paper clips...make sure your using the right type of paper....try resetting the printer, unplugging, waiting for about 20 seconds then plugging back in. Check and make sure connections are all securly connected...if none of this works you could have a hardware problem.....if you have a warranty it would be a good time to call them...if not a local computer or hardware repair shop will also work
well, it is in the manual under engine oil. turn key to on, dont start. press gas pedel to the floor "slowly" 3 times within 5 seconds. if the change oil light flashes, its resetting. If not, repeat.. this worked for me.
Pull out the toner cartridge. Carefully put your fingers into the opening just beyond the chrome roller. A little to the left of center you will fell/see a small black plastic finger which sticks up. It should be loose - push it forward and it springs forward, release it and it returns to the original position. If your paper jam catches this finger it can become jammed and will feel rigid. Put light pressure on it either pushing to the back or pulling forward until it becomes free again. Replace the toner cartridge, close the cover and your red light should go out.
