Question about Belkin N1 Vision Router
My N1 vison keep losing on wireless connection when i used 2-3 wireless devices in same time. My connection is wired to my Desktop PC & wirelessly to 1 laptop, 1 iPhone and newly 1 iPad. I noticed that when i used all 2-3 wireless devices together for 5-10 minutes, it losing all wireless connection but wired connection is just fine. eg. It asking password on my iPad / iPhone when try to reconnect even i enter it correctly, it repeated asking and no connecton. I have to restart by unplug router and it back to normal even no need to put any password on any devices because in fact it is remembered.
    Genius:
  • 1,584 Answers
If you have a 3G phone in the house, It operates at the same frequency and is a nono.
If not I would suggest you completley rest modem and re-enter U/N, P/W etc and set up secure network also. If still a problem, maybe faulty modem.
Posted on May 10, 2010
How many pc's, laptop's & printer's can i link up to belkin n1 vision wireless router model f5d8232-4
You can uplink a fairly good number of PCs or laptops with Belkin N1 as it supports high bandwidth. Keep in mind that upon adding every new PC, the overall bandwidth for the other PCs is reduced. If the PCs/ laptops do not require much bandwidth, you can connect / add more PCs to the network.
Generally, I have uplinked upto 10-15 clients to one router and the network worked just fine. It all depends upon the network environment and the bandwidth usage by each client PC. If the PCs are using just email and simple internet browsing (and remain idle for most of the time), you can add more clients to your network as not all the systems consume network resources at the same time.
Hope it helps! Good Luck!
CreativeTECH
Apr 01, 2011 | Belkin N1 Vision Wireless Router
My belkin n series keeps losing internet connection hard wired to my computer and three wireless computers in the house. when hard wired to the virgin broadband modem everything works fine
I would suggest taking a look at your modem LEDs. What happens exactly when you lose connection? A look at the LEDs should give you some thought as what might be causing this. You can also try resetting your Belkin to default factory settings by pressing the Reset button at the back for 30 seconds, and then putting back your Belkin settings.
Nov 16, 2010 | Belkin N1 Wireless-N Wireless Router
Keep losing internet connection
Hi Dave,
I got your issue , You have mentioned that you are losing the internet connection through the router .
To fix this issue You need to update the firmware on the router . I have given you the link to download the firmware from the website
http://en-us-support.belkin.com/app/answers/detail/a_id/527/kw/8231/r_id/166
1.You have not mentioned the version number of the router , so please check the version number (in the bottom of the router)
For example: If its version 4000, then you have to download 4xxx firmware which is in the link.
2.After downloading the firmware from the website, save this file in a location where you can easily identify(eg: desktop)
3.connect the comp to the router with the ethernet cable to the router in any one of the wired slot and open the browser(eg: Internet explorer) and in the address bar type 192.168.2.1 and enter.
you will be logged into the router setup page.
4.Look on the left side of the page under Utilities , click on firmware update
5. then if its asking for login password, leave the password as blank and click on submit.
6. then click on browse and choose the file from the location where you save and then click update.
Once after firmware update you will not have any problem in loosing connection. please try this I'm sure it will work.
Thanks & Regards,
Prema
Oct 09, 2010 | Belkin N1 Vision Wireless-N Wireless...
Frequent wireless connection loss using usb port
since it is a USB device try this:
http://www.fixya.com/support/r3567552-resolving_intermittent_windows_usb_devic
other things you can do, update the:
BIOS Wireless Driver Video Driver (Effects power management)
May 20, 2010 | Dell Dimension E310 PC Desktop
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Help with my wireless router
you have the internet on desktop pc and you want to connect your laptop right?
open control panel select network set up wizzard and follow instructions for shared network.
if you connect dsl to notebook you need to have installed modem device drivers and configured device and done basically everything you had to do on pc,by disconnecting dsl from pc obviosly youre gonna lose the internet.
get your self a wireless router if not already have one , that way you set up pc wired and link laptop via wireless
Jan 09, 2009 | Computers & Internet
Belkin N1 Wireless USB Adapter
Hi Emma,
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Please let me know how you make out.
thanks
Jan 21, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Sep 16, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin N1 Vision Router Logo
346 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
