Question about Kenmore Dryers
Kenmore 90 series dryer, motor wont start, loud
Kenmore 90 series dryer, motor wont start, loud buzz then breaker pops, it will reset in a few minutes but it will not start. Is there a start relay or is the motor done?
    Problem Solver:
When you push start button there is a humming noise and dryer won't start i release the button and noise stops. there is a burning smell. I cleaned the lint from under the dryer and around. I checked the belt and manually rotated the drum no binding. is it the motor or start switch? or what?
Jan Jones
Email: janjones1342@cox.net
ph: 619-429-5996
Posted on May 12, 2010
    President:
  • 1,382 Answers
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
Posted on May 10, 2010
Kenmore gas dryer made a loud buzzing sound and didn't start. I smelled burnt rubber smell. Dryer is totally unresponsive now. Breaker is ok, power is on.
Sounds like the belt has burned and broken. There is a switch on the tensioner that will not let the motor run if the belt breaks.
Dec 28, 2009 | Kenmore Dryers
Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
May 08, 2009 | Dryers
On my kenmore 90 series dryer the barrel won't turn
most of the time when that happens it's the dryer motor getting weaker and weaker until one day it just stops and then all you will get when you push the start button is a buzzing sound,i see this all the time on kenmore"s-mike
Apr 22, 2009 | Kenmore 62602 Electric Dryer
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore gas dryer buzzes but does not run
sounds like the start windings in the motor have gone bad. The only way to fix this is to replace the motor.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
Kenmore 90 series gas dryer
possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Sep 29, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
395 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
