Question about Acer AL1916W 19" LCD Monitor
Acer 1916W flickers which started 2 days ago. Can this be corrected?
    Genius:
  • 1,584 Answers
Borrow replacement monitor and if good, not usually untill a part is replaced.
If the same, then fault is in the PC.
Posted on May 10, 2010
I have this model N3735w Viewsonic LCD flatscreen TV and it is flickering. The screen is also getting darker.
Try turning off the automatic brightness feature . This mode adjusts the brightness according to the light level in the room.
Dec 26, 2013 | ViewSonic N3735W 37 in. LCD TV
Black screen on acer aspire 9300
Hello, have you tried reseating the memory, taking out memory and installing another? It could be a faulty memory module and if it isnt that sounds like the graphics processor on the motherboard is faulty. That requires advanced soldering skills. Hope this helps.
Chat Live Remote Support
Facebook
Feb 22, 2013 | Acer Aspire Computers & Internet
Acer 1916w flickering
Its either going to be a problem with puffy capacitors on the main board or the lcd is going bad on it cause the backlight can't stay on.
The cost of fixing the monitor may be more then what a new one is worth but you wouldn't know unless you bring it to a repair shop and have them look at it.
Try another known working monitor to see if you get the same symptoms, if they go away then you know the original monitor is bad. if you get the same symptoms then the video card is bad.
Jun 26, 2009 | Acer AL1916W 19" LCD Monitor
1989 honda accord lxi fi oil light
Sounds like there is an oil pressure problem. Now this can be due to several factors. 1. low oil level in car
2. bad oil pump
3.bad oil pressure switch /sending unit
4. last but not least check oil filter and make sure its not clogged.
worn engine main/connecting rod bearings.
have pressure checked with a manual guage at oil pressure switch for the correct pressure. If that's good then the switch is bad and problem solved.
if it low then you will have to check pump and bearings. Contact if you need more help and thanks for using FIX YA
May 15, 2009 | 1989 Honda Accord 4 Door
Acer X223W flickers using DVI cable, but ok with VGA!!??
Acer X223W flickers using DVI cable, but ok with VGA!!?? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715G2892 2 3 Acer PWTVAC21MQDL Power Supply for X223W
Dec 19, 2008 | Acer 22" X223w LCD Monitor
Repairing the MB for the (Acer) AL1916 monitor
http://www.eletromaniacos.com/Downloads/Monitores/Acer/acer-AL1916v.pdf
Apr 24, 2008 | Acer AL1916W 19" LCD Monitor
Acer 1916w dissassembly
dear alanwilson04
if your monitor is under waranty then it is better to give to the shop from you have purchased.
if not then you call a qualified person to solve the problem because working inside the monitor is dangerous
Mar 04, 2008 | Acer AL1916W 19" LCD Monitor
Green backgroud instead of black
sounds like your monitor cable is either bad or has a bent or missing pin on the connector.
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
