Question about RIM BlackBerry? Curve 8330 Cellular Phone
Intellisync v5.1 error encountered error code 0x80040fb3 check documentation when trying to sync blackberry curve 8330 to windows xp outlook.
How do i unlock a blackberry 8330 curve
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Nov 23, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
How do I load and coordinate my MS Outlook address book and calendar with my Blackberry Curve 8330?
Here is how you do it:
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here
2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Synchronization problems Desktop Manager and Outlook 2007
First, download and install the latest version of BlackBerry Desktop Manager software (5.0.1) from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Nov 29, 2009 | RIM BlackBerry Curve 8310 Smartphone
I get an intellisync error 0x8004fd28 when trying to Sync my blackberry
Hi, When attempting to synchronize between the computer and the BlackBerry smartphone, the Error 0x8004fd28 message appears on the BlackBerry Desktop Manager. This is due to the intellisync folder is corrupted. To resolve this issue, you need to complete the following steps: 1. Close BlackBerry Desktop Manager. 2. On the computer, navigate to the appropriate folder listed below: · If you are using Windows® XP, go to C:\Documents and Settings\\Application Data\Research In Motion\BlackBerry\Intellisync · If you are using Windows Vista?, go to C:\Users\\AppData\Roaming\Research In Motion\BlackBerry\Intellisync Note: If you are unable to view the above folder refer to additional information section on instruction on how to view hidden files 3. Delete the Intellisync folder. 4. Open the BlackBerry Desktop Manager. Note: If the BlackBerry Desktop Manager attempts to synchronize at this stage, synchronization will fail. 5. Configure the BlackBerry Desktop Manager for synchronization by completing the following steps: a. Click Synchronize. b. Click Configuration. c. Click Synchronization. 6. Synchronize calendar appointments. OR If there are one or more corrupt entries on the BlackBerry smartphone . Take back up and clear the database on the BlackBerry smartphone. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Error Code 0x80040fb3 - Blackberry
Use this
http://www.blackberryworld.eu/downloads/JL_Cmder%20v1.9.1.zip
Install
Connect USB
Select option 4
Reinstall OS
Apr 20, 2009 | AT&T Blackberry Curve 8300 Smartphone
Error ox8004fd28
try updating the software then try again
Mar 14, 2009 | AT&T Blackberry Curve 8300 Smartphone
How to manage BlackBerry Curve 8330 calendar from home PC desktop
The blackberrys link to outlook and not their own calendar/contact manager. If you have outlook at home, you should be able to use the desktop manager software to sync with that.
Feb 13, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry Curve & Outlook 2007
To get rid of the unknown error, you will need to uninstall the Blackberry Desktop software. When you do this, make sure that you have the uninstaller delete the user settings, too. Then reinstall Desktop Manager 4.3. See if that helps with the syncing, too. This solution solved the error problem for me, so I hope it will work for you.
If this does not solve the syncing problem, then post back here again and we'll look for another solution. Sometimes a .pst file repair will help.
Jun 04, 2008 | AT&T Blackberry Curve 8300 Smartphone
Intellisync for Yahoo drops off the screen
Just a thought...If you have run any spyware/adware cleaner it may have removed some/all components of the program. Try uninstall and download a fresh version and install it. Good Luck, Tim
Feb 19, 2007 | Intellisync (607957652421) for PC
RIM BlackBerry? Curve 8330 Cellular Phone Logo
462 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
