Question about ASUS A7N8X-X Motherboard
On, reset, both indicator lights place ment for wires on the 12 peg terminal
I have six wires to place all two wired colors. I know the black and green is the on button but in all I have no idea what prongs to place them on. I cannot find the motherboard A7VBX-X
    Genius:
  • 1,027 Answers
This Link will take you to the web site enter the version # and download the pdf manual.
Posted on Mar 28, 2008
  • Mark Williams
    Mark Williams Mar 28, 2008
    Sorry that link is for the A7N8X-X
    This Link is for your boards manual
No spark when starting
COIL ON DISTRIBUTOR MAY BE SHORTED...
USE A 12 VOLT TESTER TO CHECK...PLACE RED WIRE FROM TESTER TO BATTERY...PLACE BLACK LEAD TO BLACK WIRE OF DISTRIBUTOR, CRANK ENGINE, IT SHOULD READ POSITIVE 12 VOLTS...IF NOT IT IS SHORTED... however this is not set in stone. DON'T USE A NINE VOLT TESTER...
USE A OHMMETER, CHECK THE RESISTANCE BETWEEN THE SIDE TERMINALS OF THE COIL, DISCONNECTED. YOU SHOULD SEE 0.75 TO 0.81 RESISTANCE. THEN CHECK THE RESISTANCE BETWEEN EITHER SIDE TERMINAL AND THE CENTER HIGH TENSION TERMINAL. THE READING SHOULD BE 10,000 TO 11,000 OHMS. ANY SIGNIFICANT DEVIATION FROM THESE NUMBERS WOULD INDICATE THE COIL COULD BE DEFECTIVE.
May 16, 2014 | Toyota Passenger Cars & Trucks
How to set up??
First, you have to make sure that the thermostat is set to conventional and not heat pump. Then, the best way to know where the wires go, is to mark what terminals the came off of from the old stat. If that isn't possible, the next best thing to do is go to the unit and see where each wire goes. This is because the wire colors are not exactly set to any certain standard. It's at the discretion of the person installing the system in the first place to use whatever colors they like, to work any part of the system the choose.
The basics/commonly used colors are:
Red- R terminal- Power
Green- G terminal- Fan
White- W terminal- Heat
Yellow- Y terminal- Cooling
Blue- C terminal- Common
Heat Pump Thermostats use more wires, such as:
Orange or Black - O/B terminal- Reversing Valve
Brown- W2/Aux terminal- Heat
My suggestion would be that your black wire is for your cooling(Y), and all other colors wire up to the corresponding terminals. There are many systems that are ran only by 2 and 4 wire setups, therefore, it's possible that whoever ran your wire initially did not have a yellow wire in the strand. Also, if there is a yellow wire in the strand(possible 7wire strand), it could also be that the wire had a short and they switch the wires to bypass the short. Hope this helps and Happy Holidays!
Dec 01, 2013 | Honeywell Programmable Thermostat Heater
Out of the white wire and black wire which is hot coming from the fuse box?in order to hook up light switch
Usually the black is Hot, and connects to brass colored screw on switch.
Test each wire to bare ground wire, and tester lights up on Hot wire.
What are you wiring?
What is a mobile?
What terminals are you connecting to? What color is each screw terminal?
What voltage are you using? Only 120volt single-phase has 1 hot wire.
If you have split-phase 230V from UK or 240Volt in US, then both wires can be hot.
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Sep 27, 2012 | Electrical Supplies
I bought Master mind for kids game, made by pressman. It did not come w/ any instructions. I need rules for the game to play the game.
The two players decide in advance how many games they will play, which must be an even number. One player becomes the codemaker, the other the codebreaker. The codemaker chooses a pattern of four code pegs. Duplicates are allowed, so the player could even choose four code pegs of the same color. The chosen pattern is placed in the four holes covered by the shield, visible to the codemaker but not to the codebreaker.
The codebreaker tries to guess the pattern, in both order and color, within twelve (or ten, or eight) turns. Each guess is made by placing a row of code pegs on the decoding board. Once placed, the codemaker provides feedback by placing from zero to four key pegs in the small holes of the row with the guess. A colored (often black) key peg is placed for each code peg from the guess which is correct in both color and position. A white peg indicates the existence of a correct color peg placed in the wrong position.
If there are duplicate colours in the guess, they cannot all be awarded a key peg unless they correspond to the same number of duplicate colours in the hidden code. For example, if the hidden code is white-white-black-black and the player guesses white-white-white-black, the codemaker will award two colored pegs for the two correct whites, nothing for the third white as there is not a third white in the code, and a colored peg for the black. No indication is given of the fact that the code also includes a second black.
Once feedback is provided, another guess is made; guesses and feedback continue to alternate until either the codebreaker guesses correctly, or twelve (or ten, or eight) incorrect guesses are made.
The codemaker gets one point for each guess a codebreaker makes. An extra point is earned by the codemaker if the codebreaker doesn't guess the pattern exactly in the last guess. (An alternative is to score based on the number of colored key pegs placed.) The winner is the one who has the least points after the agreed-upon number of games are played.
Jul 19, 2011 | Video Game Consoles & Games
2007 Chevy silverado (classic). Once hooked up to trailer, the brake lights do not work only turn signals on trailer.
firat of all check and make sure you have a real good ground or otherwise you will lose current to another wire and this can short out and cause the lights to malfunction.
White: Ground
Brown: Running
Yellow: LT and Stop
Green: RT and Stop
This is the wiring code for the 4 wire trailers and
Wire a round seven-pin hitch, typically sold without a wiring harness, to the vehicle observing the following color codes: Run a white 10-gauge wire between ground and terminal one, run the blue 12-gauge wire between the electric brake controller and terminal two, the brown 14-gauge wire between the taillights and terminal three, the black 10-gauge wire between the permanently live 12-volt supply and terminal four, the yellow 14-gauge wire between the left turn/brake light and terminal five, the green 14-gauge wire between the right turn/brake light and terminal six and the purple 14-gauge wire between the backup light and terminal seven (in the center).
Feb 18, 2011 | 2007 Chevrolet Silverado Classic SS New...
New blower motor and new resistor. Blower motor still not working. What do I check next?
switch. Use a 12 volt test light at the resistor connector. Take connector off resistor, check the brown/orange stripe wire for 12 volts--is it hot? if yes, connect your test light clip to that terminal and probe the other terminals. Orange/black wire terminal should light up with setting on high. Black wire terminal should light on any setting, etc.
If brown wire with orange stripe is not hot, check fuse 9.
If fuse 9 is OK, problem may be in the mode selector switch.
See diagram and let me know if you have any questions.
Dec 23, 2010 | 1989 Mercury Topaz
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
ASUS A7N8X-X Motherboard Logo
110 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
