Question about Kenmore 24 in. 16532 - Multiple Color Built-in Dishwasher
Kenmore Ultra Wash, Smart Wash light blinking red.
The last time we used our dishwasher was about 3 or 4 days ago and all seemed fine. Over the past few days I've been in the kitchen numerous times, and never noticed any blinking lights on the dishwasher. I come home from a Mothers Day dinner for my mother-in-law and discover that the Smart Wash led is flashing and the timer is set to 2 dashes (--). Nothing in the kitchen seemed out of the ordinary - all the clocks were still set. Thinking some kind of power trip anyways, I reset the breaker in the basement. This didn't solve it. Pressing any buttons seems to get the Quick Rinse led to flash along with the Smart Wash led. Pressing cancel will turn alternate the timer from displaying (--) to nothing. Apon reseting the circuit, the dishwasher briefly turns on, makes the sound like its draining, the Smart Wash light will remain solid for aprox 30 seconds, then start blinking. We had tried turning the power off to that circuit for about 5 minutes, with the same results above.
The control panel shows that it's an Ultrawash, QuietWash model 4, with Smartwash.
Modes:
Smart Wash
Anti-Bacterial
Pots
Normal
China
Quick Rinse
Hi-Temp Scrub
Sani-Rinse
Air Dry
Delay
Cancel
The sticker on the door reads:
Stock: 16532
Type: 575-0
Model: 16532200
I had attempted to find the error codes for this unit online to no avail. Any help on getting this solved will be great, as right now the dishwasher is half full and we cant run it.
Carlo
  • 279 Answers
SOURCE: LIGHTS FLASHING ON THE PANEL
If the reset procedure (those buttons you pressed) didn't work, it's because the machine is still reading a fault. It could be a few things... water temperature too low (indicating a bad heating element), partial blockage of the drainage hose, or something preventing the spray arm from spinning. If letting it sit for a while allows it to start again, I suggest you do that. It will stop again and the lights will start blinking. When it does, open it up immediately and see how much standing water there is. If there is a lot, look for a blockage in the drainage hose. That's the most likely, I think, because it makes sense that it would work again once the water slowly drained. If there isn't much water, then see if the water that is there is hot. If it's not, then it's the heating element. Checking for movement of the sprayer arm is a bit trickier, as it won't be moving while the thing is open. Though, if the first two are not the problem, there's a good chance that is. Or, of course, it could be a malfunctioning control panel giving false errors. There's really no way to test for that, unfortunately - but I don't think it's acting like that is the problem.
Posted on Sep 11, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
Daniel S
  • 4323 Answers
SOURCE: I have a Kenmore elite
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jun 19, 2011
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Kenmore Ultra wash mod.# 665-77963K703. normal wash light flashing. How do I reset.
How many times does it blink before pausing and repeating? 7 times? (That's a common problem - means "water not heating" error.) In some dishwashers, instead of pressing Heated Dry, Normal Wash, Heated Dry, Normal wash, you press the 3 left-most keys in the following order: 1, 2, 3, 1, 2, 3, 1, 2, 3. That will start the diagnostic cycle and clear the error, but if you don't find and fix the cause, the problem will come back the next time you run the DW. But before I try to explain how to fix the root cause, I would need to know how many times the light is blinking.
Jan 09, 2015 | Kenmore Dishwashers
How can I fix this problem: Kenmore dishwasher Ultra, less than two years old. All of the buttons on the left of the control pad are not operating except the 'rinse only' button. buttons on the right...
sounds like you have a problem with the touch pad. it may need to be replaced. on the Kenmore that I had that was one of the things I had to replace when it was just 18 mons old.
May 21, 2014 | Dishwashers
I have a Kenmore Ultra Wash Dishwasher model# 15867990. The Sani Rinse light stays on and when you press another button the lock on button comes on and then the dishwasher will not start. I have tried...
Hi
It may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 17, 2011 | Kenmore Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore Ultra Wash Quiet Guard 3 problem
Thanks Munkee,
I started having this problem, blinking green light,  three days ago with my Kenmore QG3 and finally was tired of not being able to use my dishwasher. I've had it for three years with no problems until 3 days ago. You solution, use of commands, really helped and no money wasted on tech assistance. Thanks again!!
Aug 20, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 16532 - Multiple Color Built-in Dishwasher Logo
290 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
