Question about Dometic Rooftop RV Air Conditioner
AC will run for several hrs, cooling then just shut off. You can restart it & it may run but not long. I wonder if it has a float switch that is cutting it off. This is a new unit. First time used. I was told to make sure the camper was level.
  • Dometic Master
  • 6,674 Answers
Camper level should have nothing to do with it. When it shuts off, can you run it in fan only mode? Pull filter down from ceiling assy.,when this happens and let me know if you see frost on the coils up in that part of the AC. Get back to me.
Posted on May 10, 2010
My ac won't turn on have thermostats set to 80 and inside temperature 94 no cool air coming out of vents
Check the drain line or emergency pan for backed up water and a tripped float switch. Never leave float switch out, must vacuum or clean drain line clear.
Jun 14, 2017 | Thermostats Heating & Cooling
AC chronotherm IV plus thermostat has no display and AC has gone off and will not come back on.
Either the 5 amp fuse is blown on the indoor unit, transformer is bad or float switch is tripped.
May 28, 2017 | Amana Heating & Cooling
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
May 24, 2017 | Heating & Cooling
Briggs & Stratton motor
try a new coil
Mar 23, 2012 | Garden
My everstar portable ac is not running properly. In cool mode only the fan is running if I shut off the unit and restart the compressor comes on and then shuts right off the green light blinks briefly and...
Ed, there are several things that can cause this problem, but all are solvable.
1. The current temperature setting is not low enough.
2. The air intake filter needs to be removed and cleaned.
3. The water collection tank is full and needs to be drained.
4. Obstruction in the exhaust hose(s).
Be sure to turn the unit OFF & unplug it, before attempting any service work on the unit.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 12, 2011 | Whynter Portable Air Conditioner
Have a acer aspire 5520,it has developed several problems,1, will often freeze on full screen mode,have to shut it down and restart,2, will keep on shutting down after battery light starts flashing,will...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Acer Aspire 5520-5908 Notebook
Toro 6.5 hp pushmower shuts off after ~ 5 mins of
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Aug 02, 2009 | Garden
Onan microquiet 40000 in toyhauler ,runs for 15minutes and off
Take and locate the oil pressure switch and try bypassing it,if that aint it check fuel filter and pump.
Jul 22, 2009 | Watts Onan Portable Generator - 4000 ,...
HAVE A COLEMAN MODEL DRHSO601CB --- THE UNIT WILL RUN FINE FOR SEVERAL HOURS WITH GOOD COOLING AND THEN PERIODICALLY THE TROUBLE LIGHT WILL COME ON THE THERMOSTAT AND THE UNIT HAS SHUT DOWN. TO RESTART -...
You may have a low pressure or high pressure switch tripping out the board as well. You might try cleaning both the indoor (evaporator) coil and the outdoor (condensing) coil. Be sure to turn off the power source before servicing this.
Jun 30, 2008 | Coleman Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
102 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
