Question about Apple iPod touch
I have a 16gb ipod touch and when i put any headphone in, the right side words and the left side barely plays. when i play around with the headphone jack sometimes it'll play but most times the left side doesn't work
  • 133 Answers
Its a kindda h/wprob u have to go any repairing shop its a minor prob
Posted on May 10, 2010
My apple iPod nano 5th gen wont play music through the headphones right. It only plays through the internal speaker even with the headphones in. I can hear it through the headphones a little but it is...
take the headphones out play the music full volume then put the headphones in and lower the music all the way down then your volume will be normal and it will only play in through the head phones unless you take headphones out then it will play through speakers
Aug 30, 2010 | Apple Logitech Inc MM50 Portable Speakers...
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
Tip
How to connect an iPod to a Tritton AX720 Touch
<p>While the Tritton AX720 headset is designed to communicate with other users play games on Xbox 360 and PlayStation 3 game consoles, can also be used to play music from your iPod to surround improving the sound. The kit comes with AX720 Controller in a row to adjust the volume of the headset to adjust, and in combination with an audio cable to connect the controller online for the iPod Touch. Unfortunately, since the iPod Touch is connected to the controller in-line, you cannot communicate with other users if you play a game simultaneously. <br /> <p><br /> <p>1. Connect one end of the stereo audio cable to the door on the right side of the controller online. <br /> <p><br /> <p>2. Connect the other end of the audio cable stereo headphone port at the bottom of the iPod Touch. <br /> <p><br /> <p>3. Connect the headset cable into the headset jack is located on the back of Tritton AX720 amplifier. <br /> <p><br /> <p>4. Connect the power cord from the power amplifier of the port, and plug the adapter into an outlet. Press the power amplifier, which is found on the front of the unit. <br /> <p><br /> <p>5. Press the "Play" button on the iPod Touch to play the music to start. Slide the wheel on the right side of the in-line volume controller to adapt the music to hear. <br />
My iPod only plays through the left headphone, not the right. How can I fix it? Thank you.
This is a common problem, the "Bulb: at the bottom of the Jack, is not making contact with the "Fingers" inside the socket. Either replace the socket, or try another sort of headphone with a bigger "Bulb". Also check, it isn't a broken wire just as it enters said Plug.
Mar 15, 2010 | Apple iPod touch
When i take out my headphones out of mu ipod touch it wont let me hear it without the headphones on
you have to hit play again after you unplug the headphones and turn the volume up using the buttons on the left side of the device, if you have no buttons on the left side then you have the 1st Gen iPod touch which you can only listen to with headphones.
Jan 30, 2010 | Apple iPod touch Second Gen (8 GB,...
Wont play through my bose system anymore
the apple ipod are very delicate and it seems that docks are very harsh on the internal workings IE: motherboard of the ipod. it not just the touch, it's all ipods.
My suggestion is to check the headphone jack and if you get sound, don;t play your ipod on the dock at all. Your dock has probably done some damage to the audio circuit on the board.
If you get sound through the headphone jack save your ipods life and just use it through the jack.
I have replaced numerous motherboards on ipods played on docks. they just don;t handle the charging and playing very well whether it's heat or just the wrong voltage I am not sure.
But my first question to a customer is have you played it on a dock.
I would stay away from the dock
Apr 30, 2009 | Apple iPod touch
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Left ear no music
Before you worry about repair, verify that the balance control in the iPod isn't causing the problem. The easy way to do this is to try some other audio device (home stereo, etc).
Mar 19, 2009 | Coby CV-190 Consumer Headphones
Headphones not playing in iPod
This is either cause by a damaged headphone socket in the iPod or a loose connection. The only way to solve it will involve opening the iPod case and inspecting the daughter board that the headphone socket is on.
Mar 06, 2008 | Apple iPod MA446LL/A MP3 Player
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Apple iPod touch Logo
96 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
