Question about Sony BDP-S360 DVD Player
BD Data in local storage will be erased Exit
BD Data in local storage will be erased Exit meomory jack on rear of unit not recognized
Can I take the memory card our or erase the memory on the card. I would like to donate this and I want it clean.
Memory Card are also type of hardware like hard Disk and are required to be protected from any unauthorized access. Deleting of Data from these cards is not enough as the data can be recovered from these data storage sights. so be careful while handing over your Memory Cards as the receiver can recover any type of data even from your broken hard disks and same goes to the other memory storage devices as the deleting or erasing does not do a needful
Apr 03, 2017 | Cameras
How do i factory reset my Samsung exhibit sgh-599n
  1. Select Home > Menu and then tap Settings > Privacy.
  2. Tap Factory data reset.
  3. Tap Format USB storage to erase all data stored on the device internal storage area.
  4. Tap Reset phone > Erase everything.
Mar 03, 2015 | Samsung Cell Phones
Device is prompting me to erase bd data usb device (rear)
Do you happen to have a usb thumb drive connected when you get the message? What, if anything is plugged into the usb port?
Dec 03, 2013 | Sony BDP-S590 Blu-ray Disc Player BDPS590
Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.
Retrieve or Erase a Fax
Press 9 6
then to
Retrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. After
the beep, hang up and wait.
Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.
Setting Fax Storage
If you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax stored
in memory.
1 Press Menu, 2, 5, 2.
2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.
3 Press Stop/Exit.
If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.
If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
Feb 07, 2012 | Brother FAX-8360P Plain Paper Laser
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
Some blu-ray discs will not play on DVD player. Error message states "not supported file format" E/mail address is Dorray2 @cogeco.ca
If the unit says something about data storage, try putting a 1GB USB thumb drive in the front lower right of Blu-ray unit... I have a Samsung BD-C5500... Had that problem when we tried to watch Narnia #3 on Blu-ray...
Apr 26, 2011 | Samsung Televison & Video
Want to update my sharp blue ray disk player bd-hp21u - does not play current disks
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
  1. Insert the USB memory device
    with the update file into the BD
    STORAGE/SERVICE terminal on
    rear of this player.
  2. Press SETUP to display the SETUP
    MENU screen.
  3. Press arrow keys to select
    “SETTINGS”, then press ENTER.
  4. Press UP/DOWN keys to select “SOFTWARE
    UPDATE”, then ENTER.
  5. Enter the 4-digit number using 0-9.
  6. Press ENTER to start checking data
    in the USB memory device.
  7. During the data checking,
    “Checking” blinks.
  8. The current version of this unit software
    and the version of the update file on the
    USB memory device are displayed. To
    update this player software with update
    file, select “YES”, and press ENTER.
  9. If the USB memory device is not
    properly installed or the correct update
    file cannot be found on the USB
    memory device, an error message is
    displayed.Check the file on the USB memory
    device, and then reinsert the USB
    memory device correctly.
  10. Press ENTER to start updating.The screen becomes dark for a
    while until the update screen can be
    displayed. Please wait for the update
    screen to appear. Do not unplug the AC
    cord
  11. When the software is successfully
    updated, a screen is displayed
    indicating that the update process is
    completed.If the update has failed, check the file
    in the USB device and try Software
    Update again.
  12. Press POWER to turn off the player.
  13. Remove the USB memory device.
Oct 18, 2009 | Sharp BD-HP21U Blu-Ray Player
My yahoo site builder has maxed out do i buy more space or go to a new building tool?
If your yahoo site builder space is out of free space then i advice you to buy new additional space to expand the current free space you have. But first please have a look and study what are the data that is no longer used in your current space in order for you to have a free space again. Maintaining the storage area for your your site is important if you have data that is no longer used then erase it or download it into your local hard drive and erase it into your site storage to have more free space available for other current data to be used.
Thanks
Aug 02, 2009 | Encore Web.com Site Builder & Hosting...
Bought s350 blue ray dvd player. when tried to play ,get error message- EXT MEMORY IN TH THE EXT JACK OF THE REAR OF UNIT NOT RECOGNISED. CHECK THE MEMORY AND TURN THE POWER ON AGAIN. NO EXT MEMORY IS...
I had the same issue. it is not recognizing the disc. I called in and I am having to send it in for servicing. The message you are getting is because the only option you are getting is the BD data one and not the one to play the disc.
Jun 05, 2009 | Sony BDP-S350 Blu-Ray Player
Memory full
1. Fax Storage may be set to On. When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions. The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, Fax Storage should be set to Off. Verify Fax Storage is set to Off by doing the following:
a. Press FUNCTION, 8 (Remote Fax Opt), then 2 (Fax Storage).
b. Check the setting. The display will read On or Off.
c. If the setting is On, press the left or right navigation key (arrows) until the display reads Off.
d. Press SET and then STOP/EXIT.
e. If you have faxes stored in the memory, you will receive a message that reads Erase all fax 1. Yes 2. No. This means you have faxes saved in the memory. If you do not want to reprint the saved faxes, press 1 (Yes) and then STOP/EXIT. After pressing 1 (Yes), all fax data is erased and Fax Storage is turned off.
Hope this helps!
May 20, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Sony BDP-S360 DVD Player Logo
714 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
