Question about Water Heaters
Ao smith water heater keeps going on vacation mode
After the power was reset in the house the water heater keeps going on vacation mode by itself please help. no hot water
  • Water Heaters Master
  • 12,061 Answers
I wonder if it is,because whenever there is a power outage, certain things do NOT respond well to the reconnected power's "Inrush Current" Often this will "Spike" the Electronic Controller, and I think that is what has happened to your, unit. I have seen it many, many time before. This fits with what you related, "after the power was reset in the house" (sic) This the thing that gives it away, is that. Anytime Power is cut, and then simply reconnected, can and does cause exactly this type of problem. You need to call a registered engineer to attend to your situation, I would imagine, they will have to replace the main controller.
There is just one chance, IF, your unit, can be "Reset" then you could try that before calling for professional help.
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/550.pdf
Service manual of a gas hot water to troubleshoot.
homerepair.about.com/od/plumbingrepair/.../trblsht_hwh.htm
http://www.google.co.nz/search?num=100&hl=en&q=+hot+water+heating+troubleshooting&btnG=Search&aq=f&aqi=g-m1&aql=&oq=&gs_rfai=
Above are some DIY help links, to help troubleshooting. http://www.chilipepperapp.com/troublee.htm
Posted on May 10, 2010
How do I set ao smith pro max model ect 52 on vacation mode
No vacation mode in this heater. I have used this for last 5 years.
Dec 18, 2014 | AO Smith A O Smith Water Heater Hot...
AO Smith Heater/Vacation Mode
Most recent power shot has intellivent gas control valve:
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Generally you can wake up the control by holding down both temperature adjustment buttons for 1 second then release.
Otherwise, add a comment and give more information, if this is new heater or old heater that stopped working, and what error code if any you are experiencing.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Post question with more detail on pro water heater formula.
More information is needed... and fixya truncates free questions so not sure I am seeing whole problem
May 14, 2013 | Water Heaters
AO Smith BTH 500 ignitor keeps burning out,is my electronic control the problem?
I would report problem to AO Smith.
Also ask question on pro water heater forum
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
If the igniter is not turning off, then that would explain early failure, and it would be caused by the control chipset
Mar 21, 2013 | A.O. Smith BTH-500A BTH-500A 130 Gallon...
AO Smith Water heater FPSH50-260 keeps blowing fuses
FPSH series is a power vented residential gas water heater.
1) The blower is plugged into 120Volt outlet. If blower has short, then it will trip breaker.
Blower could be Fasco model 7021-10195, or 7021-10770. Call AO Smith: 1-800-527-1953. They will need model number and serial number located on label on side of tank.
2) Before calling AO Smith, check outlet with circuit analyzer. Outlet must have correct polarity and must be grounded. Unplug cord to water heater and run continuity test from ground prong on electrical plug to manifold tube on gas valve.
3) Also if a fluorescent light fixture is on the same breaker, that can cause burner to short cycle.
4) Connect water heater to different outlet and see if problem continues.
5) AO SmIth has service manuals for the FPSH series that download to your computer:
Sep 20, 2011 | Water Heaters
My white rodgers control panel is set on vacation (green light) is on. I have held down the arrow buttons to get it off of vacation mode but it is not working. Obviously i need to switch it off as we have...
Water heater and gas valve are not clear:
Add a comment with description of water heater and gas valve for possible help.
Open following link for White Rodgers intelli-vent gas valve thermostat:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
1) Typical instructions for Kenmore and AO Smith water heater with Intelli-vent say:
Set on-off switch to ON position.
Hold down both arrow buttons for 1 second.
Then press hotter button.
2) Also check that 120Volt electrical outlet has power, and check outlet with cheap circuit analyzer from home center.
3) If Intelli-vent gas valve thermostat is malfunctioning, and won't reset, then contact manufacturer of water heater for replacement gas valve.
Label on side of tank will have Model number, manufacturer, type of gas LP NG, serial number for part ordering.
Add a comment for more help.
Jun 10, 2011 | White Rodgers Water Heaters
Water Heaters Logo
768 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
