Question about Craftsman Garden
When I turn on the power it just hums. It sounds like it want to run, but will not. It turns easily, so it is not frozen.
  • 12,061 Answers
Basic Fixes Start your troubleshooting by ensuring your Craftsman chainsaw is fully fueled with the proper mixture. According to Craftsman's instructions, use a mixture of gasoline and 2-cycle engine oil to fuel the chainsaw. Mix the ingredients at ratio of 40 parts gas to 1 part oil. Do not mix the oil and gas in the fuel tank; use a gas can. In addition to making sure your chainsaw is fully fueled, make sure it the blade is clean and the chain is well-oiled. Dirt and debris can wreak havoc on the operation of a chainsaw. Start-up and Running Problems Make sure you are following the proper starting procedure for a Craftsman chainsaw. Slide the STOP switch down, place the choke in the up position, and press and release the primer button 10 times. Place the chainsaw on a flat surface and hold it tightly. Place the throttle in the open position, move the choke to the middle position, pull the cord four times and the chainsaw should start. Let it warm up for 10 seconds and move the choke into the lower position. Make sure the chainsaw's choke stays in the lower position while running it; otherwise, the engine will stall. Mechanical Problems If you still can't get your Craftsman chainsaw to function properly, look at mechanical causes. Remove the top cover and check the spark plug. If the plug looks corroded or black replace it with a properly gapped plug. Make sure the connector is securely attached to the plug. Drain the chainsaw of oil and fuel and check all filters. Remove the spark arrestor screen from the back of the chainsaw and replace it if it is dirty or damaged. Remove the top cover and remove the air filter. Clean it with warm water and allow it to air dry thoroughly before replacing it. Remove the fuel filter by pulling it out of the fuel tank with a bent wire. Disconnect it from the hose and replace with a fresh filter. Finally, remove the bottom panel from your Craftsman chainsaw and use a bent wire to remove the oil filter. Replace it with a fresh one. Do not attempt to adjust the carburetor. Craftsman chainsaw carburetors are set at the factory, and Craftsman recommends they only be adjusted by a qualified service professional. Source: Craftsman.com Craftsman Gasoline Chain Saw Operator's Manual http://www.ehow.com/how_4540077_chainsaw-troubleshooting.html
Posted on May 10, 2010
Kenwood fpm800 stopped
Hi, Like any washer if you smell something burning and a humming from the motor I suggest you take out any cloths in it and try turning the inside basket clockwise to see if it turns freely and if it does then the motor is defiantly shot but if it won't turn freely then either something is jammed between the inner and outer tub or the transmission if it has one is bad or the bearing housing is bad so try and disconnect the belt from the motor and see if the motor runs and if it does then follow from the motor to the tub and see what is frozen .
Good Luck
Gynoman
Sep 13, 2014 | Washing Machines
My 230 bernina does'nt move when I press the foot switch, just humming.
Sounds like the motor is either frozen or the machine is frozen. Humming means the motor is trying to turn. Is there an external hand wheel which will allow turning the machine by hand? If the machine has been in storage for a long time, the lubrication can become 'glue-like' causing difficult turning. This may require a trip to a service shop--hope this helps!
Dec 27, 2010 | Vacuums
Car ran out of gas in when the temp was zero. Added 3 gallons of gas and it still will not start. Car turns over. We checked to hear the fuel pump go on by listening for the humming sound in the open...
Frozen gas line? Add about a cup of gas line antifreeze or some methanol (methyl hydrate or methyl alchohol) to the gas tank, then jump up and down on the bumper to agitate/mix it in a bit. Wait about 10 minutes and any frozen gas line would be thawed.
You're sort of on the right track with the rest. If you run out of gas and then cranked, and cranked trying to get it going before filling up with gas... you may have damaged the pump because it relies on the cool gasoline to keep it cool.
If the fuel pump is working properly, it should make a noise when you first turn on the ignition, and then shut down as the pressure builds up in the whole system. If you are hearing a CONSTANT hum, then it may be trying to pump but can't and keeps on trying and trying and may be burning out.
Some fuel pumps actually have a "reset" button that gets tripped if the pump gets too hot. Often access is somewhere through a plastic access panel near the back of the car. The exact location is likely in your instruction manual if you still have it? Also
To replace the fuel pump often requires that the fuel tank be dropped by loosening two metal straps and then the whole fuel pump unit is easily accessed and replaced. You may wish to have a mechanic do it OR if you choose to try to do it yourself, repost with a new subject so some of the auto mechanic experts can lead you through it.
Good luck,
/denis
Dec 15, 2010 | 1993 Pontiac Bonneville
I replaced the fuses with the proper ones thinking that that was why fan on ac unit was not on. I did the 24 hour off on electrical panel, and replaced fuses, now i hear a click then a humming sound coming...
The humm you hear is the compressor. Turn your unit on and let it run for a couple minutes and grab the large pipe at the outdoor unit. If it's cold, your compressor is running. If your fan didn't turn on, there is a good chance your motor is fried. It could be your contactor, but I doubt it. The compressor and fan are wired through the same contactor, so when one comes on, so does the other. DO NOT run your unit for more than a minute or two with the outdoor fan not running. If you continue to run it, it's going to go out on high pressure and turn back on, and so on, and so on, until it fries the compressor.
Sep 28, 2010 | Carrier Heating & Cooling
Both fridge / freezer are not cooling down. It sounds like the motors are not working.But there is power going in. Also there is a small humming engine noise.
Are you sure the humming noise is from the compressor motor being locked up? It is normal for the compressor motor to make a humming noise when it runs. Make sure the fan in the freezer is also running while the compressor motor is running and replace it if necessary.
You need to defrost the coils in the back of your freezer. You can do this the slow, easy way by simply unplugging the refrigerator for 24 hours. Leave the doors open to ensure everything has the chance to melt.
The fast way to defrost the coils is to turn off the refrigerator and remove the rear panel from the freezer compartment. You will see the evaporator coil completely frozen with ice. Thaw the ice with a hair dryer and make sure you thaw the drain at the bottom of the back wall as well.
When you turn replace the freezer panel and turn the refrigerator back on, it will get cold again.
Mar 06, 2010 | Electrolux Refrigerators
BACK OF DYYER HOT BUT NOT INSIDE DRUM
That sounds like the motor is not turning (which drives the blower). Push on the door switch and watch the drum for turning while starting. Is there any loud humming? It might be the motor trying to run. If the motor turns easily by hand (power off), check the motor to see if it has a capacitor attached to it. If the capacitor fails, the motor won't start.
Sep 14, 2009 | Frigidaire FDE336RE Dryer
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Dryer hums when turned on but won't tumble
SOUNDS TO ME AS IF THE MOTOR IS FRYED IT WILL START RUN FOR A WHILE THEN STOP ? I WOULD CHECK INTO CHANGING IT OUT OR A NEW MACHINE WHAT EVER IS EASIEST ON YOUR WALLET DURING THESE TIGHT TIMES GOOD LUCK
Nov 04, 2008 | Frigidaire FEQ332E Electric Dryer
Outside unit will not operate
Sounds like a bad fan motor. Inside fan runs, compressor runs. Outside fan. Are your contactors pulled in when thermostat set on cool? If not might be a contactor. If contactor not pulled in touch the top of it with the end of a screwdriver. If fan spins turn unit off a buy a contactor...
Tip: Always make sure power at disconnect is off
Jun 10, 2008 | Carrier 38CKC042 Air Conditioner
Garden Logo
224 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
