Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Mower will not disengage
The mower blades will not immediately disengage from the engine when the mower lever is released. I sometimes have to put the mower in reverse to make the blades stop spinning
  • 3 Answers
This is because your belt that drives the blades is to tight i suggest getting a looser belt
Posted on May 10, 2010
Release blade engagement attachment lever craftsman #917259330
there sure be a lever to disengage on the fir =e wall of the lawn mower deck or near fire wall o the lawn mower
Oct 16, 2014 | Garden
Blades keep running in all gears on my mtd 420/38
Assuming you have put the blade drive lever into 'disengage' check the blade drive belt tension. With blade disengaged, belt should have significant slack. You may need to adjust the control cable, adjustment is usually on the mower deck; or you may have some debris on the deck preventing the pully to release belt tension
Jun 26, 2014 | Garden
What makes the blades on a riding mower stop turning once the mower belt is disengaged?
The brake mechanism works when tension is released from the idler / cable. The brake is spring loaded to contact the spindle this stops the blades from spinning. I have attached a drawing showing the brake arm and where it can be found on the deck.
afzvk1vyaxgoaaaaaelftksuqmcc
Apr 15, 2017 | Poulan Garden
I just bought this lawn mover and recoil starter does not pull up?
You have to squeeze the safety lever on the handle to disengage the blade brake. This lever is meant to be squeezed while you operate the mower and will stop the mower instantly (well, pretty darn quick) if you release it while the mower is running.
Jul 06, 2011 | Mtd Yard Machines 158cc Briggs and...
I have a mountfield 1538h-sd blades disengaged while mowing belts seem very slack ,but the belts are all on the pulleys.
The belts may be loose.With the mower off,engage the blades and check the tension.Next would be to get under the mower and check for debris in and around the lever that engages the blades.Sometimes trash will get hung up in there and the blades will disengage.The next step would be to inspect the pulleys for debris and to make sure the spindles are not bent.While at the pulleys make sure there are no burrs or cacks in the pulleys,as that will cause the blades to disengage.
Jun 03, 2011 | Garden
Husqvarna ride-on mower LT1536. We put a new
This seems to be the correct part no. for the 36" deck, is the belt definitley the correct one, it should have the no. 174978 marked on it.
Sep 29, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
After replacing the belt, new pulleys, and bolts, my mower wont disengage the blades when i disengage the lever. when i start the mower, the blades are off, but once i engage the lever, they start, but...
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Oct 17, 2009 | Craftsman Garden
Have a 19 hp john deere zero turn riding mower. starts up, blades turn, has oil. will not move forward or backward. does the hydrolic oil level have anything to do with that?
ck on traction motors for lever or nut to release fluid. Can you move mower with engine off?
If so, this is your what is wrong traction motors
are disengage
Aug 30, 2009 | Garden
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
I have a DYT400 with a Briggs and Straton Intek plus 19.5 ovh. When I move the speed lever to full speed, the mower wants to choke out. Also, when I put the lever on stop, it just keeps running. the...
You have governor with a missing spring or it could be in the wrong place. If the springs are all OK then you may have a bad governor gear in the crankcase. This engine is bad about the governor gears bending the governor gear shaft.
Apr 25, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
579 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
