Question about Fantom Vacums FM741 Twister Bagless Upright Vacuum
I have fantom FM741H It sadenly stop working. I checked plugs,circuitbraker. They are Ok. What is possible problem? Thanks
I have the same sweeper as you. I have had this sweeper over 10 years. I purchased it from HSN. Model fm741h. Ok here we go. I paid 299. for it 10 years ago. It worked perfectly. Picked up all sorts of things. It stopped working about 5 years ago. I kept it hoping I could get someone to go over it with a fine tooth comb in my area. No one worked on them. So I still kept it. Just today 09/4/2010 I was looking at it. I decided to start taking the whole unit apart. I come to find out all the filters are clogged. I have never replaced them or the belt. The belt was fine, the motor runs, but its just not picking up anything. So inside the canister was caked with dirt. I mean literally DIRT. Inside the part that spins is another filter. I checked the prices on those. Anywhere between 23.00 up to 50.00. So I took a toothbrush and ran it under hot water. Scaped off all the dirt, let it dry and presto....I have my TWISTER back. YIPPY!!! I can't see spending that much on a filter when all you have to do is scrape the dirt off of it. Works perfectly. Now that I know what to do....I'm a happy camper.
Posted on Sep 05, 2010
I lost the inner filter that is inside the big filter of the fantom vacuum. What is that part called. the vacuum model # is FM741H
if you have lost it, you really should try EBAY, as for what it is called, even I with my exerience dont remember what exactly it was called. However, you will not find a new one now because that model has not been made since 1999.
Good luck.
Nov 15, 2010 | Fantom Vacums Lighting Canister Vacuum
Sweeper wont pick anything up. When the motor runs it sounds like the belt is broke, but it is not. It revs real high. There are no clogs and the filters are clean. I have no idea what it is, and I...
to me it sounds like a blockage?having worked on these machines for so long,when the motor runs high as you say then its under pressure im not convinced you have cleared the blockage take another look ,i use a old wire coathanger straightened out to push the rubbish out,if that fails,go out and buy yourself a new machine you derseve it and you will be surprised at what the new machine can do..adrian,,,,
Sep 06, 2010 | Fantom Vacums FM741 Twister Bagless...
Cant find one
Hello. You can call the Fantom company directly at 800-798-7395. Or use their website http://www.fantom.com/fantom/default.aspx
please rate my answer as very helpful. thanks. Joe800-800----
Apr 21, 2010 | Fantom Vacums Lighting Canister Vacuum
My Fantom Fury upright beater bar stopped working.
Hi at the bottom of the vac were the roller brush is there is a cover you would have to take that off and then you will see were the belt is located
Oct 07, 2009 | Fantom Vacums XT450K Upright Vacuum
My fantom vacuum stopped sucking stuff up
Most likely there is a clog, either in the 'knuckle' between the power head and the wand, or in the connection where the hose comes into the canister. In either case, unplug the hose and you should plainly see it.
Mar 07, 2009 | Fantom Vacums Lighting Canister Vacuum
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
I want to download a manual for fantom cyclone xt
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=558003
Generic problem for all Vacuums
Posted by dotbeeman on Apr 29, 2008
I want to download a manual for Fantom Cyclone XT
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The best way is to go the Fantom website that I will include @ the bottom of this response and to see if the website will allow you to download the owner’s manual, or you can call the Fantom Factory / Manufacturer and they will most of the time send you out an owner’s manual to the cust or @ least make copies and mail them to you. You also can check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Customer Service – 1-800-798-7395
For technical support, please call us toll-free at 1-800-798-7398. Hours are Monday through Saturday from 9:00 am to 6:00 pm Eastern Standard Time.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 29, 2008 | Vacuums
Fantom Vacuum powder head Parts
In Canada I don't know. Parts for the older Fathoms are getting scarce. There is a wholesaler here in the US that has parts, but you have to be a repair shop to buy from them and I don't know if they are in Canada. Call your local repair shops to see if they can get you that circuit board, the co. name here is Essco, or Electric Sweeper Service Co. Wish I could help more.
Apr 24, 2008 | Fantom Vacums Lighting Canister Vacuum
Fantom Twister
On my fantom cylone I use a 2 foot wire with small hook. Open bottom and push wire up the vacuum channels. There is also a channel that goes to the brush. Check for suction at hose. If none then your one of your channels going up are blocked. If you have suction at hose but none at floor brush then channel to floor brush is plugged.
Dec 09, 2007 | Fantom Vacums FM741 Twister Bagless...
Fantom Vacums FM741 Twister Bagless Upright Vacuum Logo
307 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
