Question about Ovens
My kenmore self cleaning oven , F06 error
My kenmore self cleaning oven , after self cleaning finished door looked with F06 massege ,how I can reset the foult
  • 530 Answers
First try to turn the breaker off and then back on and see what happens.let me know if this helps and what is the model number?
Posted on May 10, 2010
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door lock is stuck locked. Using self cleaning function and now door won't open. Is there a trick to it.
If the oven is finished with the self cleaning cycle and cooled down, it should automatically unlock the door.If it doesn"t, try unplugging the oven to see if that will reset
Jan 09, 2011 | Ovens
Oven door locked with code F06 - this was after it had been on self cleaning mode. any suggestions on how to open the door?
The unit has to be cool for the solenoid that powers the lock to open. If the unit is cool, unplug or switch the appliance off at the breaker. Problems after cleaning cycles are an extremely common occurrence. The heat often fries circuitry and causes all sorts of misery for consumers. If the oven does not reset, please look at your error code again. The codes are usually either 2 or 4 digits, not 3. I am not familiar with FO6, probably because the appliance is made for Spain? In any event, in the U.S., F0 is the electronic board behind the clock. Please try the unplug/power step and let me know if it doesn't work. Thanks.
May 18, 2010 | Whirlpool RBS275PD Electric Single Oven
Oven door will not unlock
Hello,, Some times this will happen after a self clean cycle if the timer did not finish the entire clean. Try to set the clock to start the self clean again then simply end the self clean. This should unlock the door. If the door remains locked. You may check the oven for an error code, or the door latch itself may need to be replaced. One other possible would be to turn off the power to the oven and try to let the oven control reset. leave the power off for about 15 minutes then turn the power back on. That will sometime work aswell. Good luck and feel free to call me if you need more help.
MIchael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Locked door light flashing
I had the same problem with a gas kenmore oven. I played with the lock mechanism (opened it a little more manually) and it fixed the problem...
Jan 12, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
273 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
