shuts off after 20 minutes says the cell needs clean. It's clean. took it to sears charged me 30 dollars to tell me it was in the circut board. Which wire can I cut to by-pass the sensor that tells me to clean the cell and shuts off the purifier? $300.00 machine that does me no good shutting off all of the time.
-   i have exactly the same problem.
shuts down every 20 minutes too with clean cell flashing..
out of the box new ebay,
worthless.
so...now what.
can this be fixed?
-   Guest
This suggestion helped me because as I was examining the cell for debris I noticed markings for "Top" and "Bottom" inscribed on the four corners of the front of the cell that I had never noticed before. After cleaning I had installed the cell upside down. It would work for 20 minutes and then shut off. The rounded thingies on the bottom of the cell are contacts which should touch the little springies on the bottom of the housing.
Was this helpful?
Yes
No
Popular Solutions for Kenmore AC2044-1 Air Purifier
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the...
(More)
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the local rainsoft dealer! The parts are: LAHV91, Rainsoft PN: 65048 and the LAHN90L PN: 65501. Can you tell me where to buy them?
i have the fresh aire model just replaced rci cell cleaned filter and cleaned the ozone plate. the...
(More)
I HAVE THE FRESH AIRE MODEL JUST REPLACED rci CELL CLEANED FILTER AND CLEANED THE OZONE PLATE. THE FAN KEEPS TURNING ON AND OFF?? STARTS RIGHT BACK UP ON ITS OWN AND THROWS NO EROR MESSAGES??
side by side refrigerator....need to take out top inside of refrigerator to replace part. How do I...
(More)
side by side refrigerator....need to take out top inside of refrigerator to replace part. How do I get the top out?
Hi, I have a Hunter Quietflo Air Purifier that has quit working on me after about 3 years of use. It...
(More)
Hi, I have a Hunter Quietflo Air Purifier that has quit working on me after about 3 years of use. It seems to be getting power bc the lights turn on like normal but thats all that seems to get power. Is there a way to check if the motor is working without replacing it? thank you
