Is my series 70 kenmore too old to put a new pump on? Model # 11082873120. I need to replace the leaking pump. I pulled the case and water is coming out of the front of the drain pump. I bought it in 1989 and all I've had to fix is the plastic agitator screw which was worn down. Not bad, huh?
  • 530 Answers
Go to repairclinic.com
type in your model number and you will find all the parts you need
I hope this helps you
Posted on May 10, 2010
Hi! I have a Kenmore 70 Series top load washer (Model 110 82873120) that has been in storage for a few months. When we hooked it up tonight and did a few loads we noticed that there is a burning smell...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082873120/0582/0153200?pathTaken=&prst=0&shdMod=11082873120
and you'll see a list of major sub-components with diagrams and parts.
Two possibilities: since it will spin. None of the suggestions are very expensive.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Jan 20, 2011 | Washing Machines
Kenmore 70 Series Top Loading Washer Leaks
If this is a Kenmore TOP LOADER, you need to remove the exterior cabinet in order to access the washer interior and sufficiently inspect to determine where your leak may be coming from. This is much easier than it sounds. The following link explains how:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
In the majority of cases with a top loader, the water pump begins to leak. These pumps are not serviceable and require replacing if damaged. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Follow the tips in the link provided and make sure you inspect all hoses and tub seals as well. This is a very simple repair that you can perform without the assistance of a repairman. The average cost of a pump is about $35.
If you have any questions, please post back with your MODEL NUMBER (located along the wash tub rim under the lid), so I can determine what washer configuration you have. I hope you find this information helpful.
Apr 22, 2010 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore series 70 squealing and leaking water
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your pump is bad.
See the following illustrated description of how to access and check / replace the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=8eaba8b07483055c9c0f23bd2274f0a8
Dec 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
Kenmore 70 series is leaking water. Could it be the pump?
It depends on WHERE the leak is coming from. If the leak is coming from the FRONT area of the washer, the drain pump or drain hoses are suspect. If the leak is coming from the REAR of the washer, the water inlet hoses, water inlet valve, or dispenser hoses may be suspect. If the leak is coming from under the CENTER portion of the wash tub, the tub seal or wash tub may be suspect.
The first step is to remove the exterior washer case to gain access to view. The following link explains how to replace a water pump (if required) on your washer, but also includes all the steps necessary to access the washer interior:
http://www.fixya.com/support/r397092-replacing_water_pump
Allow the washer to fill about 1/3 of the way and turn it off before unplugging and removing the washer casing. The washer will not run once you disconnect the lid switch connector, so you will need some water in the tub to see where the leak may be coming from.
NOTE: If the problem IS a leaking pump, these pumps are not serviceable and will need to replaced.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Jul 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer model 70 leaking
More than likely the pump. Very easy fix. To keep from being redundant I prepared a page on direct drive coupling removal and replacement. The pump must be removed to fix this item therefore it pertains to your problem. Plus you can watch for leaks better with the cabinet removed. To read click HERE.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 18, 2009 | Kenmore 22422 Top Load Washer
Kenmore Heavy Duty 70 Series Model 110 water leak
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Mar 16, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
