Question about Whirlpool ET8CHEXSQ Dryer
Power failure code on dryer
We have a Whirlpool Dryer that keeps giving a PF code although there has been no power interuption.
  • 530 Answers
Check the power cord where it connects to the dryer.
is it burned?
Posted on May 10, 2010
PF code comes on
Check all the wiring to the dryer and even the wires in the wall socket. Sounds like there is a loose wire since you keep getting the power failure (PF) code on the dryer.
Dec 27, 2011 | Whirlpool GGW9868K Gas Dryer
What does PF stand for? getting that message several times lately
What you could do is get the service panel off the base of the machine.
On the backside of it is the tech sheet which gives explanations of the codes given.
You would thin it stands for Power failure and it might just be a faulty breaker. They recommend the washer have its own dedicated line without any other things on that line. Some codes require a ground fault interupter on the receptacle near any machine that uses water in case of flooding. That could be causing the PF. themobilian_2.png
Nov 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I recently moved and now my dryer is flashing PF
According to Whirlpool, all you need to do for “PF” (power failure),
is check the following:
Was the drying cycle interrupted by a power failure?
Press and hold START to restart the dryer.
To view the owner's manual for your dryer click on this link & choose the model # that you have from the list.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WED8300&siteCd=WHRCOM&userType=Consumer
May 27, 2010 | Whirlpool WED8300S Dryer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Apr 21, 2009 | Dryers
The dryer will not turn on its flashing pf
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Apr 15, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool duet gas dryer PF error will not reset as per manuals
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool gas dryer doesn't run. error code pf shows on lcd
pf usually means power failure. Try to clear the screen or hit the off button to clear pf and then see if it works.
Nov 16, 2008 | Whirlpool GGQ8831L Gas Dryer
PF Code on Duet Electric Dryer
just press cancel ..pf means power failure ..if still not clearing probably control
Aug 15, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ET8CHEXSQ Dryer Logo
105 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
