Question about Mitsubishi LT-3780 37 in. LCD Television
Mitsubishi lcd lt-37131 keeps shutting off, have to wait one minuet to turn back on.
Agent Aaron
  • 265 Answers
SOURCE: Mitsubishi LCD Flat panel HDTV LT-46131
Hey BooBoo198,
One of the most common reasons why this may occur is if your TV has encountered a recent power fluctuation/surge or has detected any kind of unusual feedback. As a safety precaution, many newer TV's will automatically shut themselves down whenever either of these are encountered. Many models will have one or more lights on the front of their case that may blink if this has happened. According to information from the manufacturer, simply pressing the "System Reset" button on the TV should resolve this kind of issue. If the problem persists however, you may wish to try using a different AC line power conditioner/surge protector.
If the TV doesn't turn on at all, this can also be an indicator that the bulb or lamp in the TV has burned out. Please keep in mind however, that it is generally best to double-check with your owner's manual documentation for confirmation of what any steady/blinking light means.
Additionally, Mitsubishi has indicated that if the "Status" light is either steady or flashing red you may need to contact a factory-authorized repair facility for service.
If you have not had any luck working with either Mitsubishi itself or Circuit City, remember that you can always contact a Best Buy™ representative for further assistance. If we don't have a repair tech in your area, Best Buy™ would be glad to locate a factory-authorized third-party service center on your behalf.
You can reach us by calling our toll-free hotline at 888-Best-Buy (888-237-8289), and asking the operator to speak with our in-home TV repair department.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 11, 2008
  • 8457 Answers
SOURCE: Mitsubishi LT-52148 lcd tv turns on for 2 seconds
The lamp LED indication flashes?When was the lamp replaced?The lamp has not been replaced 1 1/2 or 2 years.The lamp life is over.Require a new lamp.
Posted on Sep 01, 2010
budmrtn
  • 11361 Answers
SOURCE: My Mitsubishi LT-37131 was damaged
It should have MOV (130~150V rating) across the Line and Neutral after the fuse, unless this TV was made to work from 100~240v range. You should check to see if the 5vdc standby is evev working right now, withot it, nothing else will happen. Checkt the DC voltage on the large electrolytic cap (the one with 150~300uF 350~450VDC rating) in the AC primary side, it should be connected to the bridge rectifier, it should have around 160vdc (120v x 1.414) on it.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 07, 2010
budmrtn
  • 11361 Answers
SOURCE: 2 year old Mitsubishi LT-46149 46" LCD Flat Panel
Does it come and go? I would try reseting the ribbon cables between the LCD panel and the T-CON board first.
The Flexible Printed Circuit BoardS (FPCB) are ultrasonic welded to the LCD TFT panel, they are not SOLDERED on! The connections do get bad due to very delicate nature of how the LCD panels are made. You can also try squeezing the around the top area of the screen where the lines are to see if the lines go away.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Dec 15, 2010
eagle338
  • 4889 Answers
SOURCE: Problem with the Mitsubishi LT-52144 52 in. HDTV
Hello. I was in a live session with you earlier and it seems like you accidentally closed the window. Does the tv tv click on momentarily before it shuts off and starts blinking?
Posted on Feb 12, 2011
My phone keeps shutting down and turning back on
Sounds like a battery issue - does it charge correctly when plugged in?
Aug 05, 2014 | Apple iPhone 3G
Mitsubishi LT-37131 has darkening spots on screen
Take a photo of what it looks like (take several) and post here or on a photo sharing site--indicate location of photos so I can see what it looks like.
In case you need it here is a listing and source for parts for this set:
http://www.shopjimmy.com/mitsubishi-lt-37131
May 27, 2012 | Mitsubishi Televison & Video
No sound at all on Mitsubishi LT-52151. Fixed before by unplugging, waiting 30 seconds, plugging back in. Was occurring more and more often to the point of having to do this every time I would turn it on....
Just fixed this on my TV today! (after 2 months of the sound intermittently failing to turn on and failing completely yesterday) Go to Mitsubishi-tv.com. Go to support. Enter your model number. You will be directed to the documentation for your model which will include a zip file for a firmware update and a PDF file with instructions for installing the update. This fixed my sound.
Mar 02, 2011 | Mitsubishi LT-52151 52 in. LCD HDTV
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
Feb 24, 2011 | Mitsubishi LT-40153 LCD TV
Problem with the Mitsubishi LT-52144 52 in. HDTV LCD Television TV will not turn on, power light flashes rapidly
Feb 12, 2011 | Mitsubishi LT-52144 52 in. LCD HDTV
My Mitsubishi LT-37131 was damaged when my electrical circuit lost the neutral wire. The voltage going to the tv was 250 volts between the hot and the neutral. The tv will not turn on and it it doesn't...
Nov 07, 2010 | Mitsubishi LT37131 37 in. HDTV LCD...
Mitsubishi LT-52148 lcd tv turns on for 2 seconds with sound and shuts off.Tried resetting.What could be the problem?
Sep 01, 2010 | Mitsubishi LT-52148 52 in. LCD HDTV
Mitsubishi 65" LCD (1080P, DLP) keeps shutting down until it "warms up". After shutting down the power led flashes yellow for a minute or so, at which time I power it up again. This cycle repeats 1 to 4...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV may require service.
Jul 27, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
Mitsubishi LT-3780 37 in. LCD Television Logo
521 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
