Question about Toshiba SD-V295
I cannot get the Vcr/ Dvd to play
I had the tv repair man out 2 days ago for an unrelated problem which he easily fixed, I showed him my dvd player which I couldn't get to play on another non digital tv he said it was incompatible so we switched it with another that was compatible from another tv he showed me that they both worked now, saw it with my own eyes. Icannot get this thing to play a DVD or VCR for life of me I've tried manually pushing play and the remote they both act like they are playing but nothing on the screen the TV is on channel 3.1 and all the cables are hooked up as he left them WHAT THE F&*^ gives here anybody out there than can help
  • 2,336 Answers
The TV needs to be on channel 3 not channel 3.1 because is a digital channel and the signal from the VCR is analog. Tune the TV to channel 3 to get the analog video from the VCR.
Posted on May 10, 2010
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
When trying to play some DVDs, the brightness fades in and out. This started to happen when I bought a new Samsung wide screen TV. Samsung says it is not a problem with the TV and must be with the DVR...
Could be either one the tv or the DVD/VCR player.Take the DVD/VCR player used it with another tv,see if have the same problems happen.If it is the DVD/VCR player dose have this problems,this problems is causes by the DVD/VCR laser eye reader,not worth fixing.The whole new DVD/VCR player only cost like 60 or 70 bucks brand new.If it turn out to be the LCD tv fault,than have very strong case to argument for the Samsung tv corporation for the tv warrenty repair.
Nov 17, 2010 | GoVideo DVR4400 DVD Player/VCR
How do I get the VCR to play on the tv? It's a Sanyo DVW-7100 DVDPlayer/VCR Combo. The DVD will play but the VCR won't show up on the TV.
This maybe too simplistic but are you sure you have the right command buttons toggled try to set the player to VCR and not dvd.
Set the player to VCR with a tape in it and press play. I hope this works for you
Sep 29, 2010 | Sanyo DVW-5000 DVD Player/VCR
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
DVD player not working properly
I have a DVD player, a VCR player, a TV set all hook into an RCA RT2250 Audio/Video receiver. Everything was working fine until 2 days ago. Now the DVD player gives me a great pix but no sound. The VCR,and TV are just fine and I have checked everything out, speaker connections, mute buttons, etc. and nothing seems to be wrong. I am thinking that some thing in the receiver got fried. Is it repairable?
Dec 13, 2008 | Electronics - Others
Color problem
CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Audio
Run a DVD cleaner (available in the computer supplies section of your local Wal-Mart) through the DVD and see if your results don't improve. It could very easily be a dirty reading lens causing the problem, especially since you report no problems with the VCR, otherwise we'd look into the possibility of a bad cable connection between the TV and input device itself.
May 19, 2008 | Samsung DVD-V5500 DVD Player/VCR
Can't get picture to show up . .
You should be connecting video in of Dvdrecorder to video out of Tv.
Samir
Feb 29, 2008 | Lite On LVW-1105HC DVD Recorder
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
Toshiba SD-V295 Logo
157 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
