Question about Maytag PYE2300AY Electric Dryer
WORN BELT ON MAYTAG ELECTRIC DRYER
HOW DO I TAKE MY MAYTAG ( model LDE8414ACE) dryer apart?
  • 10,319 Answers
Remove the two brackets on the back holding the top on. Then pry the front part of the top off with a flat screwdriver. Next remove the electrical connectors. The remove the front panel. Then pull the drum out. Install the belt and push the drum in place placing the belt correctly into the tensioner for the belt
Posted on May 10, 2010
Maytag gas dryer making keening noise
Bonnie, Belt may be getting bad, change belt and check for worn bearings etc while apart.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 02, 2016 | Maytag Dryers
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
Makes a terrible noise and sounds like it need greased. How do I get it apart to grease it.
Hello & Welcome to FixYa
Though I believe the issue is bad/worn out/broken belt and needs replacement however, you can check this video on how to replace the belt & how to take it apart for greasing:
Please get back to me if you have any other questions.
Kevin
Jan 20, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Trying to put four prong cord on dryer don't know what to do with green wire the grunding screw is outside the cover then the cover won't fit model LDE8414ACE
Four prong cords are usually code in multi-unit dwellings, and mobile homes. Green wire is typically ground, so you got that part right. You may have to bend the cover, or cut off a corner, or just leave it off.
Jun 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Model pyet224ayw electric dryer, The belt broke and I replaced it. Now when I put the new belt on, every time that I turn it on the belt jumps off the tention pully. Can the problem be that...
http://www.applianceaid.com/maytag-dryers.html
this site has proper belt routing pictures for several brands maytag included might be helpful the only other thing i can think of the idler may be worn out or bent or drum may be tight not turning properly should turn freely with belt loose from inside dryer
should be able to push vanes and rotate drum easily
good luck ron
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
Very loud metal on metal screeching noise maytag model LDE8414ACE
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Loud metal-metal "screeching" sounds will eminate from the front bearing glides, (click on link below), for a picture of the glides. Link provided by www.repairclinic.com, they provide repair parts, disassembly procedures and diagrams.
You may also want to inspect for foreign objects in the front and rear drum seals and in the blower.
Drum rollers may sometimes cause loud noises also.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di1309&PartID=1309
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di1245880&PartID=1245880
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di400518&PartID=400518
Jul 16, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
309 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
