Gibson front load washer will not spin
My frontloading washer wil not spin and makes a crunching sound below the door.
  • wndpwr Mar 28, 2008
    Tech17, Many thanks for the help. I took the pump out and found a nickel in it. Just put it back together and it pumps and spins fine now! Thanks a lot for trying to help me.
  • robert samples May 11, 2010
    with the washer off turn the tub by hand and let me know if you still hear the crunching sound
Well it turns out that the machine will stiil not spin with water in it. After putting the pump back in (after finding the nickel in it), the machine went into the spin (with all water drained from the basket from my taking out the pump). To confirm that it would spin I put it into a full wash cycle. At the end it would not spin and all water remained in the basket with the clothes. I'm wondering now if it will not spin because the water is not being pumped out and it is not being pumped out because the pump impeller was damaged by the nickel and therefore the pump needs to be replaced?
Posted on Mar 28, 2008
    President:
  • 1,314 Answers
Well lol thats what i was going to tell you to do if you didnt hear the crunching sound with the power off but good for you
417.39022890 Frigidaire Gallery Frontloader won't spin
Does it move at all in the spin cycle? If it does, try to open the door during the spin cycle and tell me if the door opens or stays locked.
Nov 20, 2013 | Frigidaire ATF6000ES Front Load Washer
GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
2009 Frontloading Electrolux washer door will not open!
When this happened in our home, we unplugged the machine, waited then plugged it in again. This reset the machine and the door immediately unlocked
Feb 18, 2010 | Electrolux EW1000i Front Load Washer
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Aug 07, 2009 | Washing Machines
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
Kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
Mar 08, 2009 | Kenmore 44102 Front Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frontload Washer won't spin or wash.
check the door lock/ latch mechanism
Sep 17, 2007 | GE WSXH208A Front Load Washer
Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Apr 18, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
177 people viewed this question
Top Washing Machines Experts
