Question about Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model
Blade removal cannot get blades off
    Sniper:
  • 53 Answers
That is because you need to hold the blade(s) still when torquing loose the blade bolts. Some of those are nasty to "crack" loose. But with the proper "6 point" socket (12 point is not recommended at ALL!) and leverage? Piece o' cake! Also craftsman does make a special tool to lock the blades down to remove them. There are also generic ones for riding type mowers (I've seen them at Lowe's) blade removal. Preventing the crankshaft from spinning is paramount to getting the blades off (Not to mention safe?) It depends on your level of mechanical expertise. Experienced? then you can do it, Not experienced? Go get the special tool to prevent the blades from spinning. Life is so much easier when you got the right tool for the job!
Posted on May 10, 2010
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
Remove blade from master force saws all
  • 1. Disconnect the saw from the power supply.
  • 2. Open the blade-clamp release lever.
  • 3. Insert the saw blade into the blade clamp as far as it will go, and release the blade-clamp release lever to lock the blade in position.
  • 4. To remove the blade, open the blade clamp release lever and pull the blade from the clamp
Blade cannot be removed Saw dust in the clamp slot
Clean the clamp slot with brush
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=masterforce+saws+manual
Dec 09, 2015 | Saws
Honda lawnmower blade broken at shaft
How To Remove Lawnmower Blade Adapter
If it's the blade that is broken, remove the two bolts that hold the blade onto the blade adapter. If the blade adapter is broken, it needs to be taken off the engine shaft. The Link shows a video on how to remove a blade adapter. Hope this helps......
May 01, 2014 | Garden
How to remove a blade from a 2.5 hp sears table 10 inch tablesaw
First and foremost unplug the unit from the receptacle. Raise the blade as high as it will go and have it set to 0 degrees in a vertical position. Remove the throat plate (usually red) so you can access the bolt holding the blade in place. The saw came with a wrench for this purpose. It may have even come with 2 wrenches. One to remove the bolt holding the blade on and another to place behind the blade on the shaft to hold the motor. If it only has one wrench look for a small hole in the blade and use a screwdriver to keep the blade from turning. If there is no tool or hole to hold the blade then use a heavy scrap piece of wood to hold the blade while you remove the bolt. As you remove the blade notice the direction the teeth are pointing and put the new blade on turning in the same direction. You just reverse the procedure to put the new blade on. NOTE: Some saws have a motor lock that locks the motor and blade in position making it easier to change the blade. Just be very careful as it is easy to cut yourself on the blade.
Jan 10, 2010 | Craftsman 10" Table Saw
Dont know how to install blade
on blade you will notice two small phillips head screws. remove both screws with thumb on blade. with other hand remove the blade. Blade has two parts. The smaller blade lays on top of the larger blade. align two blades together. Hold the blade compartment in your hand upward with smaller blade on top of the larger blade. On the clipper in between the two hole where screws go there is a small arm with a round shaped tip. Put the base on to the blades a fixing the round shaped arm into the blades ensure proper fitting. With hand holding the clipper turn over while thumb is holding the blades in place and replace screws.
Oct 07, 2009 | Andis 01690 Hair Trimmer
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Aug 02, 2009 | Garden
How to clean the blower wheel/housing
Yes you can.
Steps for allure 2/qs2 3/qs3
blade located to the left (squirrel cage)
1.remove filters
2.remove both screws retaining metal plate underneath filters
Now you have room to remove the blade completely for washing.
The blade is only held on by pressure (no tools needed)
When re-installing, make sure the plastic lever on the blade is securely located in any hole on the motor face.
For allure 1
Blade located dead center of the hood
Steps
1.Remove filters
2.Remove pin
3.Remove blade (only held on the pressure) you may have to pull hard
4.When re-installing: make sure the flat side of the hole in the center of the blade is alined the flat side of the shaft of the motor.
Jan 30, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model Logo
159 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
