Question about Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP)
I need to know u r wireless networking - Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP)
You can find whether your network is a wireless or wired by verifying your router. step1:see whether your are having one incoming wire and outgoing wire. step2:rigth click on network place which is on desktop step3:click property
step4:there you can thus your network is a wired or wireless
Posted on Jun 19, 2010
Having trouble with wireless networking adapter
An Xbox 360 console can connect to Xbox LIVE using your wireless network. You do, however, need to know your wireless network password.
You can find your wireless network password in the following places:
Find your password on your hardwareFind your password using Windows 7Find your password on the router configuration webpage
Oct 11, 2011 | Microsoft Wireless Network Adapter Xbox...
Virgin has installed. D link wireless router (home address) I have 2 laptop xp window vista and pc upstair they detect the vg 50Mb broadband but can not connect ! When I go with my 2 lap top elsewhere I...
1.
Open Network Connections
2.
Right-click Wireless Network Connection, and then click Properties.
3.
On the Wireless Networks tab, do one of the following:
• To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
• To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
4.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
• To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
• If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-300 Wireless Router
Cant acess the set up wizard
First you will need to check the wireless settings of the router. If you don't know the wireless settings of the router then you will need to open the set up page of the router and get the wireless settings. You will need wireless network name ( SSID ) , wireless channel, type of the wireless security and wireless network key or passphrase.
Click Here to know how to check the wireless settings of the router.
If you know the wireless settings of the router then you will need to open the set up page of the WET54G and put the same wireless settings on the wireless briidge.
To access the set up of WET54G Click Here
Feb 18, 2010 | Linksys : WET54G Wireless-G Ethernet...
I dont know how to connect my wireless internet with the 3d reach
are you trying to connect to the wireless network.
connecting to the wireless network is not difficult. First you should know the wireless settings of the router like the network name and security key if the network is secured.
once you have all the wireless settings of the router, you just need to connect to the wireless network.
Click Here for step by step by instructions.
Feb 11, 2010 | Netopia 3-D Reach (TER/GUSB-N1)...
My new laptop with Windows7 OS cannot connect either wireless or direct cable to DLInk DI624. I have tried turning off my firewall but still same problem persist. The router is working fine with my old pc...
Adding a wired computer or device to the network.
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you are adding a desktop or any other device to the router which will always be connected to the router with the Ethernet cable, then in this case you don't need to do anything.
You can just connect the Ethernet cable between the router and the computer and it should work.
If you are not able to go online even when it is connected properly then check IP address of the computer.
Adding a wireless computer or device to the network.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
click Here for step by step instructions
Dec 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a belkin router set up in my home and I just purchased a 2nd laptop but I am unsure how to add this new laptp to the connector
Click Here for step by step instructions
Dec 27, 2009 | Belkin (F5D7231-4) Wireless Router
I misplaced my cd to connect my other laptop to the wireless router, WRT54G, and I'm trying to get it through your site
If your router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
Click Here for more info
Dec 19, 2009 | Linksys Wireless-N WRT150N Router
I need to add a password to my wireless network
Do you want to secure the wireless network ?
For that you will need to access the router set up.
You said that you want to add a password. I don't understand that. Is your wireless network already secured ? Or you want to make it secured ?
If it is already secured then it must have the password to connect to the wireless network. You can use only 1 password for the network. You can not use 2 password for the wireless network.
If your network is not secured yet then you will need to make it secured and enable password protection on it.
Click Here to know more about how to make it secured
Nov 12, 2009 | Computers & Internet
Right, do not know what I am doing but here goes....connected desktop pc to wireless router, then tried to do the same with my Fujitsu Amilo laptop and can't, i've gone into adminstrator command prompt...
Make sure first that you know the wireless settings on your router. Take note of the SSID (wireless network name), wireless channel, wireless security settings (WEP/WPA, preshared key/passphrase/wep key/wireless network key).
For Win XP/Win Vista: On the system tray (lower right corner of the screen; near the clock), right click on the double-monitor icon that says Wireless network connection. Then select View available wireless networks.
You should detect the SSID or wireless network name. Highlight it, then if it asks for a network key, you need to type the wireless network key. Then click connect.
Hope this helps!
Oct 22, 2009 | Computers & Internet
Wants a network key # to activate
Sounds like windows has thrown a wobbly regarding your wireless network connection. Go into network connections and double click on wireless network adapter. Click on wireless network tab at top of box then highlight your wireless network and click on remove. Restart your computer then let windows find the network again. Click on connect then input your wireless key again. This should refresh the connection completely. If you need more help let me know
Jun 09, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP) Logo
51 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
