Code for the philips universal remote controlto the sanyo television
SOURCE: search codes for the remote to control my tv
My remote is a PHILIPS MAGNAVOX UNIVERSAL.. Inside is a number CLOO7. Problem is after putting batterys in I am to program remote with PM335 how do I do that? Hope someone can tell me .....Thanks
Posted on Dec 10, 2007
SOURCE: Programming a Jensen JER 422 universal remote to a Sanyo Television
To Sarah,
In order to program your TV:
1. Manually turn on your component.
2. Press and hold the component key you wish to program, in your case the TV key.
3. While holding down the component key press the four-digit code using the number keys (0-9) to enter it.
4. After the fourth number is entered, the illuminated ON-OFF key turns on. At this time, release the comonent key. If the illuminated ON-OFF key turns off, you have entered a valid code.
NOTE: For Sanyo TV it could be any of the 8 next codes:
1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
Good Luck !
Carlos Vallejo
Posted on Jan 03, 2008
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
SOURCE: Find the codes andm menue for remote uRC3605B00 remote control
hi , i need the codes for ONE FOR ALL remote control 7540 . can you help me ?
Posted on Feb 16, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
Tip
Universal Remote Codes
There are a lot of people looking for remote codes. There is a manual. It is a pdf file that can be downloaded to your computer easily. The website is http://www.replacementremotes.com/MANUALS/Download-FREE-One-for-All-Codes-Code-manual.html
If you have a Philips Universal Remote control you may find your code at this look up link: http://www.urc.philips.com/
If you have an RCA Universal Remote control you may find your code at this look up link: http://www.thompsontv.com/rcarc.html
There is a youtube video showing how to program a certain kind of RCA remote to any television/device without a code: http://youtu.be/5YHGdPOy5dc
If you have a Sanyo Universal Remote control you may find your code at this look up link: http://us.sanyo.com/dynamic/product/Downloads/GXDB%20universal%20remote%20codes-42567844.pdf
If you have a G. E. Universal Remote control you can find codes here: http://www.jascoproducts.com/support/universal-remote-codes.asp
on May 05, 2010 | Televison & Video
Need codes and instructions to program Sanyo universal remote B21309 to a Philips Vcr/Dvd player.
Sanyo universal remote b21309 manual - logo - Tuars.com
ititoso.tuars.com/sanyo-universal-remote-b21309-manual/
Sanyo Universal Remote B21309 Please help find the manual for Question AboutSanyo Universal ... RMT-D153a RM-AX4000 Manual PDF instruction manual.
Sanyo Universal Remote RMT-U100 User's Guide ...
tv.manualsonline.com > ... > Sanyo Universal Remote
Sanyo RMT-U100 Universal Remote User Manual. Page 1. Page 2. Page 1 ... TheSanyo Universal Remote Control features large glow-in-. the-dark basic .
Nov 01, 2015 | Philips Televison & Video
Philips PM435S Universal Remote
I need the proggraming codes for a JVC TV and a NEXXTECH Dr30G0DVD player
Jan 21, 2009 | Televison & Video
Setting up a Philips Universal Remote for a Sanyo television
check out Philips support website for codes and instructions for that individual remote. most of their codes are the same for most of their universal remote controls. I suggest getting the original replacement remote for your TV because then you can easily just put batteries in the remote and not have to worry about programming and loosing codes. get the original at www.replacementremotes.com and at the top of the site just type in your model number of you TV and click search. They will set you up with your original remote.
Jun 07, 2008 | Philips Magnavox Learning Universal Remote
Tv Remote
Thats not unusual as the tvs are newer than the remote.
the sanyo manual will recommend a code but it will not likely work this is a common issue.
Jan 23, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
