Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Drum bearing replacement on a Bosch WFF1200 - is this an easy job
  • 116 Answers
SOURCE: Bosch model WFF1401 : Noise
This usually indicates that there is an issue with the motor or rear bearing. This can be isolated by first removing the power from the machine the removing the inner rear panel from the machine. You should be able to see the belt and motor. You can spin the belt off easily then reapply power and place the machine in a spin. Keep clear of the motor as is spins around 18000 rpm. Let the motor stop and remove power from the machine. You can spin the inner tub by spinning the large pulley by hand, if there is a excessive noise or grinding feel then the bearing will need replacing. The belt can be spun back on and the machine run with the rear cover off but again be very mindful as this cover is there for a reason.
In most of the cases the moise is from the motor itself. There are rebuild kits available but they are mostly a waste of money. The motor if worn should be replaced. They should carry a multi-year warranty, check your manual.
Posted on Jul 28, 2008
SOURCE: indesit wash machine drum bearing
Some models like the WE12 have sealed drums where the bearings can't be changed. You have to buy a complete unit for about £120.
Posted on Jun 23, 2008
  • 53 Answers
SOURCE: Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
Posted on Mar 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: Hotpoint WF321P
It appears your bearing has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Bosch waa24160gb/01 washing machine - Replacing Drum Bearings
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Why won't it agitate or move drum?
Screeching noise is typical to drum's broken bearing issue.
See some infor about issue:
How to Diagnose Drum Problems in Washing Machine
How to change drum bearings on washing machine
How to Change the Bearings in LG Washing Machine
How to replace washing machine bearings on Bosch Neff Siemens and some...
Some more video there... explore
Now, if you don't find it so easy to replace those bearings or you are not sure if this is your problem, call a repair service
Aug 18, 2015 | Washing Machines
How to fit bearings in wfl 2260 bosch max washing machine
dose drum has to come out also replace element
Mar 02, 2015 | Bosch Washing Machines
Why won't my Bosch machines drum turn?
My guess is the drum support bearings have broken up and seized. This is a job for a good DIY engineer or a domestic appliance engineer. Parts are not too dear, just a bearing / seal pack and a belt but look at the time you have had the machine versus the cost of fixing it. I know Bosch are good and expensive but so is paid help. It might be cheaper to buy another?
Aug 01, 2014 | Bosch Washing Machines
There is brown oil coming down the 2 supports for the drum so the bearings may be gone how do I replace them
Check on YouTube with your bosch bearing change demo; excellent vids there. For parts look in Fixya.
Click helped if helped
Mar 26, 2013 | Bosch WFL 2063 Front Load Washer
My maytag dryer is making horrible squealing and scaping sounds. What is probable problem and how do I fix it? I have dryer out but see no access to front panel.
hi the noise you hear is going to be the drum bearing it sounds like it has collapsed and will need replacing if your is the model shown in the picture then its the back of the dryer you need to get to you should then see the center of the drum and this is where the bearing is located its not an easy job to replace and if any damage has been done to the part where the bearing runs on the drum then this would mean any new bearing you put in would also not last very long so if their are scratch marks or sharp edges then this means the drum will also need replacing.
if you remove the back and take the drive belt off then try turning the drum with the belt off you should feel its a bit tight or you should feel it grinding, you could actually try doing that now open the door and try turning the drum by hand and see if you can feel the grinding.
the bearing will need replacing and possibly the drum depending on how much damage has been done to the drum due to the bearing collapsing,
if your doing the job yourself then you may need special pullers to pull the bearing casing off as the chances are this has been welded to the spline due to the heat caused by the bearing falling apart, its not an easy job to do but it can be done.
May 23, 2010 | Maytag MDE308DAYW Electric Dryer
I need a bearing for the ghw9100lw2 is that sold separate from the rear drum
No. the bearing is molded in the rear drum. The rear outer tub runs around $200 and it is not an easy job. I recomend having a technician replace it.
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do i get a bosch front loader drum apart, to get the bearings
THIS CAN BE DONE EASILY WHEN YOU HAVE DONE A FEW LIKE ME, HOWEVER FOR A BEGINNER ITS QUITE INVOLVED IT TAKES ME A COUPLE OF HOURS TO DO.YOU WILL NEED A NEW REAR TUB SECTION COMPLETE WITH BEARINGS A TUB SEAL AND A SEAL KIT (NEW BOLTS INCLUDED) AND POSSIBLY A NEW INNER DRUM AS REMOVING THE INNER DRUM FROM COLLAPSED BEARINGS IS NOT EASY WITHOUT DAMAGE TO DRUM SHAFT,IF YOU STILL FEEL CONFIDENT REPLY TO MY POST AND I WILL GIVE YOU MORE ADVICE.
Sep 01, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Noisy bearing on drum
This is not an easy job on any washing machine. The AEG is probably the same as most washing machines in that it has two bearings on the shaft at the rear of the drum but it also has a carbon water seal on the inside and usually you will need to change this too as if you disturb the bearings it will surely leak. If you have never done this before it can be dreadfull. If your drum has bolts and a seal at the back to withdraw the inner drum and back plate out the back of the machine then you are lucky and you should be able to do the job in about two hours. If you dont have a removeable back on the drum you will have to strip the whole machine and remove the drum supports and hydraulic pistons at the bottom. All hoses and pipes and wiring attached to devices on the drum will have to come out as well as the door seal and soap dish rubber connector. Good luck.
Apr 03, 2009 | LG Washing Machines
Bearing noise on Indesit WDG1295
you will have to open the machine lid to see if its a plastic drum or metal.
the metal drum is easier as it has a 'spider asssembly'. remove this after taking off the pulley by taking out the bolts that hold it and bang it off being carefull of the heater element. remove the bearings and seal and refit in reverse order you took it off.
i would not advise replacing plastic drum bearings as they are a pain, removal of the rear of a plastic drum easy but not putting it back !
Feb 01, 2009 | Washing Machines
Drum makes loud whinning noise when spinning at high rpms.
Remove drive belt.and turn drum by hand, if it feels rough or sounds noisy, then the main drum bearings have failed., also check that the main drum pulley is not loose. If you think it is the bearings, then it is quite an expensive repair.
Plz rate this solution.Thanks.
Dec 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
78 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
