Question about Dewalt & Variable Scroll Saw
Dust blower segment attached to the machine cracked and broke, howdo I reattach it?
  • 345 Answers
I can only suggest you try some very strong glue, there are a variety of glues available these days for plastic, steel, or anything that are very strong. if it is plastic or steel, it could be welded back on. or if it still under warrenty, take it back for replacement.
Posted on May 10, 2010
Cement counterweight broken
difficult to do much there. you could try gluing something to the bowl, but it is very unlikely to hold for many cycles. you can buy new outer bowl / frames from the manufacturer.
Nov 19, 2013 | Whirlpool Calypso GVW9959K Top Load Washer
Reattach wand, it broke off at the black part on my DC 17 Animal
short of using epoxe etc which may not bond to plastic material I would call Dyson to see if the part can be replaced or what? I am sure you are not the only one this has happened to.
Dec 19, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Blower fan not working
Locate the blower motor and remove it, or have some skilled enough.
Try removing the top motor cover and blow all the crude out of it, dust can accumulate, reattached the wiring harness and turn on the ignition key and turn on your heater, if the blower fan doesn't work replace it.
May 30, 2012 | Air Conditioning and Heat for Ford Laser
How do i replace heater moter
For 4.0L, inside the engine compartment, on the passenger side firewall, remove the coolant overflow bottle retaining strap remove the coolant overflow bottle and bracket. Unplug the blower motor. Remove the 3 blower motor bolts.Remove the blower motor. Remove the blower motor fan from the motor shaft for access to the motor attaching nuts. For the V-8, you just need to unbolt the blower motor to remove.
Mar 16, 2010 | 1996 Jeep Grand Cherokee
Dryer was making loud squeeking noise then quit tumbling. The spring was not attached. How do you reattach the spring?
You can try to bend it to get it to work, but get a new one, the old one has lost it's tension and is fatigued and the other part of the spring is somewhere in the dust.
Feb 28, 2010 | Washing Machines
Belt fell off - can't see how to attach it GE
place belt onto motor shaft, then slowly turn drive wheel while holding belt into place. when on adjust to correct position so belt stays central
Feb 11, 2010 | Washing Machines
My encoder strip on my v305 printer is not attached, i dont know where or how to reattach, anyone have a clue?? thanks
If it is not installed anymore then it probably broke on one of the ends. Check to see if you have a little square hole on each end. If you do then you will have to remove the cover to reattach. There is a hook on each end of the printer that the square hole attaches to. There is also a slot on the back of the carriage assembly (where the ink cartridges go into) and the encoder goes thru that slot and then attaches to the ends.
Nov 06, 2009 | Dell V305w All-In-One R840635AU InkJet...
Trouble shooting blower motor on 1997 dodge gran caravan
Check the heat/ac relay first making sure it is working.remove it clean the contacts and reattach. Then check the Resistor component. It is usually located near the blower or on the blower motor itself.It is attached with a couple of screws and a plug between the blower motor and the wiring. Please vote if this helps you.
Jan 25, 2009 | 1997 Dodge Grand Caravan
DC-17 - Reattaching the U-Bend piece in the back of the machine
on the back of the machine you will see 2 guides where the peice should just slide easily check for dust
Oct 20, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dewalt & Variable Scroll Saw  Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
