Mitsibishi got a 2-4 code on a wt-42313
  • 8,617 Answers
Check the code again, the K20 chassis mitsubishi which is your model will only flash 4 codes they are 1-2 2-1 2-2 and 2-3. Check the codes again and I should be able to help you as the other site that I am a tech with has the service manual in our data base
Posted on Mar 28, 2008
SOURCE:
4-2 error code. Power supply just clicks everytime and shuts off.
I think you mean 2,4 and it is vertical--think this was posted before and I did answer this.
Oct 16, 2012 | Mitsubishi WT-42313 42" Rear Projection...
WT-42313 - Won't turn on. TV gives and error code of 24. I found that this is an issue with vertical deflection. I need to know how to repair this issue.
Ck pico fuse F9A05 5amps it will be green or yellow looks like resistor if bad, replace Both STK ICs STK394-250 and 2 resistors R8c13 &14 3.9ohms also resolder all 3 yoke plugins on board.
Sep 20, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Wt-42313 wont turn on
first you can email me [email protected] and then 3 blinks is deflection circuit problem---what was wrong with set to begin with?
Sep 07, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Power on 2 sec. then off won't turn mitsubishi wt-42313
with this model there may be a liquid spill on the signal board this is because one of the tubes is leaking
Jun 17, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 TV
I found the schematic (downloadable PDF) for $7.99 at http://www.completeservicemanuals.com. Cheapest I found and highly recommended.
The blown fuse was due to a fried convergence IC. There are two of these on the high voltage board; they should be replaced together as a matched set. The bad one had gotten so hot I only had to unsolder three pins -- the rest were already loose!
I found the ICs at http://www.electronic-repair-kits.com, also highly recommended. The correct part for the WT-42313 is STK394-250. Make sure you order a pair and they will send you a matched set.
My set is now operating; I just need to clean the optics and do a convergence alignment.
Sep 01, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Turning on my tv set
Same issue - our successful fix, at least temporarily, is to unplug power cable from outlet for at LEAST 4 hours...pref. overnight.
Jul 15, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Screen cut off on the bottom - WT-42313 Mits 42"
Make sure your remote is the official Mit remote, and that it is set for TV, usually the far left setting at the top of the remote.
These remotes control many different devices. Some will allow video to work without allowing audio to work.
TV will allow all to work.
Mr Bob
Jan 23, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 color problem
see if this helps you out
http://www.digitalhome.ca/forum/showthread.php?t=21847
Dec 03, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Ekse
