Question about Health & Beauty
C954 re-furbed treadmill is making a lot of noise when putting any pressure on the belt. This is commercial!
  • andy_c_harri May 10, 2010
    What is your suggestion? It has a new deck and belt on it. Applied some wax, but does not help any. I just got it on Friday and have not even used it beyond testing it out. I decided to post a question first, before using it.
  • 787 Answers
The C954 has a class A noise emission, meaning it's quiet. You need to have it checked before someone gets hurt due to a malfunction.
Posted on May 10, 2010
  • Tudor Valean
    Tudor Valean May 10, 2010
    What I mean is take it to an authorized service so that they can check for any about-to-fail parts. This is the best thing you could do.
Treadmill keeps stoping
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Jan 27, 2014 | Life Fitness Treadmill Precor C954 (Used)
My treadmill stops wen runing on it and brings up er 27 on screen
Corrective Action
My treadmill stops wen runing and brings up er 27 on screen
Corrective Action
9500 hr belt stops when stands on it and funny noise from machine , noise stops when adjust front tension bolt but belt still loose
see the video and proceed. This happen because the lack of maintenance schedule . If the problem remain after you did LUBE is time to replace the old board belt. God bless you
Apr 01, 2013 | Life Fitness Used 9500 HR Treadmill
I have a reconditioned Precor C954. It has been sitting unused for at least two years. I plugged it in and the fan on the motor turns on, however the console does not light up. Perhaps a fuse issue?
You can start with checking the fuse, but I would also verify the correct voltage is making it to the lower board. Start at the wall outlet and follow the power through the cord and through the on/off circuit breaker. If you are getting power to the lower board and not to the console up top, it could be one of a few things. It could be the lower board, the wiring from the lower board going to the console, or the console itself. You will need a multimeter in order to do the proper troubleshooting. I will attach a link where you can view the service manual for your machine. There will also be a link to a video on using a multimeter.
http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Generic%20Service%20Manuals/COMMERCIAL%20TREADMILL%20GENERIC.pdf
Video about Multimeter Testing
Jan 19, 2013 | Life Fitness Treadmill Precor C954 (Used)
What os the meaning error 42, 49, 45 on the treadmill C954?
This erron had implies with the elevation motor.
Please RUN the software calibration for diagnose, troubleshooting and fix it.
God bless you
Jun 08, 2012 | Precor C954i Commercial Treadmill
I have a proform380i that makes a lot of noise when started... I think it needs oiling .... where do i put the oil in the treadmill ?
Unplug unit remove motor shroud then plug unit in then start it observe where the noise is coming from. The best way to check the rollers to see if the bearings have failed is using a long shafted flat tip screw driver and place it on the shaft of the front roller, then put your ear on the handle and listen, if the sound has amplified then the roller is defective and needs replacing. If not then check the The drive motor the same way last but not least check the rear roller by placing the screw driver on the end of each adjusting bolts. If the noise is a squealing noise then it could be the drive belt .Call Icon Fitness to order part their is 1-800-999-3756.
May 05, 2010 | Proform 380 Treadmill Walking Belt
Treadmill will not maintain the correct speed.
You can get a book by calling 1-800-999-3756. The treadmill you are usine in a cheaper model. the motors on those units are not that strong. when you incline your unit gravity make the belt move faster. Remember incline put a lot of pressure on you lower spine. This can cause injury for some.
Jan 29, 2009 | Proform XP Weight Loss 620 Treadmill
Health & Beauty Logo
20 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
