TV Problem When I turn on my tv at first the screen goes blue and then I see horizontal lines across the screen but the lines are curved in on the outside. After 10 seconds of seeing this on the screen it shuts off and the light for the "ON Timer" is blinking green. I tried to use my remote to turn off and on the TV but the remote wouldn't correspond with the TV. Also the power switch on the front of the TV doesn't work either. In order to turn the TV off I have to unplug the cord from the outlet. This process happens over and over again. Is there anyway you can help me with this problem? Thank you for your time, Artur Zawada
  • pradyballu Apr 03, 2009
    i have given my television in repair but the memory ic is gone i am not getting the ic please help
Memory ic lang yan pogi
Posted on Mar 28, 2008
Older big screen hitachi w/pip tube tv and has blue lines across the screen turn off on it own sometimes.
It could be time to retire the TV.
The blue almost horizontal lines are probably a fault in the flyback blanking and the fact that it will turn itself off is likely due to a poor solder joint on a circuit board inside.
Jun 26, 2016 | Hitachi Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Blue lines on screen
Go to a unused video input and examine the screen----if you see blue with slightly curved trace lines the blue screen control for the set is set just a bit too high.
Dec 03, 2012 | Samsung PCL5415R TV
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
32 ''Sanyo DP32648 TV has horizontal line running across screen
If you do not have any bad capacitors Problem will be the Display Panel
Call Encompass Parts Distribution or visit their website and type in your Model number 1-800-638-3328
Apr 28, 2010 | Sanyo Televison & Video
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
