Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Leaking out of left side
Our dishwasher has started to leak from the left side... but only for a few seconds after starting up. All that is there is a plastic piece that is glued to the side of the DW. A black hose runs up the side and into this opaque plastic piece that has a lid that seems to be able to flip up. I believe this is where the leak is occuring. Any ideas what is causing this?
  • Jenn-Air Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 29, 2010
Dishwasher leaking
When does it start to leak? I mean how much water goes in before the leak starts. I have a problem every once in awhile with mine leaking when the float in the bottom of the washer gets stuck and does not shut off the water. The way to check this is to locate the float, it is near the front left side, and push it up and down a few times to make sure it is not stuck. Try the washer again. If that is not the problem u could have a leak from the drain under the dishwasher. Sometimes the plastic can crack and cause a leak. Also check the discharge line and make sure it is not the problem.
Apr 20, 2014 | Whirlpool DU810SWPU 24" Full Console...
Dishwasher Leaking Water Front left side (when facing)
Had a similar situation with my dishwasher. Turned out there was some hard water build up on the rubber gasket. I would start there first. I would not use any harsh chemicals on it, (it may jeopardize the gasket) it usually flakes off. Hope this helps.
Nov 20, 2013 | Maytag Dishwashers
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Dishwasher leak
must need a new air tube or worse still the air chamber has a split in it
clean machine out in w/shop and with sides off check out with a light to see where the leak is realy comming from it may be leaking from the top wash feed pipe leaking around pipe to tub
these do fracture there and water running down to base
if so replace feed pipe
Jan 21, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Frigidaire Dishwasher
This is a simple solution, the brass nut that connects the heating element to the base of the dishwasher is cracked and needs replaced. It takes just a few minutes to replace, just remove the nut after TURNING OFF THE POWER and take to your local parts store, they should have one in stock. You might have your model number with you. Appldoc
Oct 31, 2007 | Dishwashers
LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
keith
Sep 20, 2007 | Dishwashers
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
132 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
