Question about Kenmore 21.7 cu. ft. Side-by-Side Refrigerator with Thru-the-Door Ice & Water with Water Filtration 4659267
Water doesnt stop after ice tray is filled
Kenmore 106.9547610
Water continues to flow to ice maker and overflows continuosly.
Fridge was turned off and sat for a month. When connecting water and power to after it sat, the water will not stop flowing to ice tray.
What detects that the ice tray is full of water an stopp the flow of water until next cycle?
  • 3 more comments
  • iflybye Mar 29, 2008
    I will test this when I get back from Vegas. I did fill the ice maker with water and turned off water supply.
    Water froze into cubes but unit never ejected the ice.
  • Anonymous Nov 23, 2008
    Not really sure what is going on but I have an Admiral frig w/ top freezer.. The ice bin always has a big block of ice in it .. The ice doesn't seem to get frozen b4 it gets dumped?? Really wierd.. Please help b4 my husband goes nuts..
  • Anonymous Feb 11, 2009
    I have a Kenmore with the bottom freezer. If the bail is down allowing the unit to make ice the water continues to drip and freeze in the tray. If the bail is raised turning off the unit the water does not drip. I assume from this that it is not the solinoid and must be in the ice maker itself. Can anyone help?
  • Anonymous Mar 20, 2014
    Wher pouring water it stops flowind and there is wates leking on follr
  • Anonymous Mar 27, 2014
    Ice maker tray is upside down
My amana sxd25s2w side by side, water dispener just stopped working all at once. I hear a click when pushing the bar, and the light goes on but no water. Also the ice maker is over flowing when it fills the tray. Are these 2 things related and I would like to replace the filter for the water , where can I find that. Please help!
Posted on May 04, 2008
    President:
  • 1,314 Answers
There is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Posted on Mar 28, 2008
  • robert samples Mar 29, 2008
    remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
The drip pan is filling up with water and then over flowing. We have to empty it once a day. Then I noticed the ice maker has stopped making ice. Any ideas?
Turn icemaker off see if water problem stops ice tray water valve may be overflowing tray cycle timer may be faulty or faulty water control valve.
Jul 31, 2015 | Whirlpool Refrigerators
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
I have a 10 year old, at least Kenmore ice maker overflowing into the ice chest. No obvious adjuster.
Can you locate the Kenmore Model Number? It will look like this=> 321.654987 What I think is the dual water control valve is leaking once it turns off. Here below is a ice a ice maker repair clip on You-Tube where he shows a slug of ice filling the ice maker fill tube. In most cases replacing the water control valve will stop the continued water flow to the ice maker once the ice maker fills. I will be here to answer any questions you have Thanks Sea Breeze
Apr 15, 2013 | Refrigerators
Ice maker is overflowing
If water continues to flow slowly after filling the water control valve for your model will need to be replaced=> 241734301 Water Inlet Valve
If ice maker simply over fills and then the water turns itself off then this points to a problem with the ice maker=> 5303918344 Ice Maker Assembly
I will be here to answer any questions you may have, Thanks Sea Breeze
Jul 12, 2012 | Kenmore Refrigerators
I have a kenmore coldspot fridge model # 106.73182302. It is only 7 years old and it is not keeping a cold enough tempature in either the freezer of fridge. The problem started with water leaking from...
my gsi 23 ice maker continues to flow water into the ice maker after the tray is full. It flows non-stop and floods the kitchen until I raise the arm that turns the unit off. I have no ice?
Sep 09, 2011 | Refrigerators
Ice machine will not stop filling with water...overflows
This sounds like a stuck water valve. Un-plug the fridge and see if the water stops flowing to the ice maker. If it stops, it's a control board (if equipped) or ice maker issue.
If not, turn the water off to the fridge, pull the fridge away from the wall, get behind it and trace the water line (small, plastic line) from the back of the fridge going down to the water valve. Remove the cover, and you may need to remove the water solenoid (the water valve) and see what happened.
Apr 27, 2009 | Refrigerators
Ice maker over flows with water
There is an orifice that controls the water flow to the ice maker . If to much water is being fed to the ice maker it will result in an overflow. You may want to check the pressure of the water system in your house.
If the overflow is being caused by a continuous feed to the ice maker your electric valve supplying the water may not be reseating after it shut off electrically. If this is your problem obtain a new valve assembly to replace it.
Apr 30, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice-maker problem
it will respond better if you fill it with scotch
Apr 16, 2017 | Refrigerators
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Kenmore 9550580 ice maker
try turning down water pressure or reduce flow into ice maker by turning tap partially off, this should resolve problem. Regards Advisor
Aug 23, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Refrigerators Logo
497 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
