Question about Amana ALW480DA Top Load Washer
Washing machine only fills half way on large setting. what is wrong?
  • 530 Answers
That usually would be your pressure switch and or the dome at your tub is plugged. take the consol off to the left side you will see a component with a hose attached to it take the hose off the pressure switch and blow through it with the tub empty...is it clear can you blow through it? if yes then your dome is clear. replace the pressure switch and this should solve you problem. sometimes i blow through the pressure switch too and sometimes this fixes that problem.
Posted on May 10, 2010
Washing machine won't wash when on large cycle
without stating the make and model it makes it harder for us to help you figure them out .front loaders are more prone to this type problem than top loaders .could be the gear box is going bad or a belt getting stretched
Oct 06, 2015 | Washing Machines
I have a maytag top loading washer. the washer if set to medium load or large or super large load only fills to the half full level,
My maytag has a rubber tube that goes from the bowl up to the level sensor. I would try removing this tube and blowing it out to make sure that it is clear and not perished.
May 26, 2015 | Maytag Washing Machines
When using my Tops injector the tubes only fill half way. What am I doing wrong?
There is a dial to control how high the water fills. It's try adjusting that. "Small, medium, large" etc. Otherwise you may have a bad float switch.
Jan 23, 2012 | Washing Machines
I have a ge profile harmony top load washing machine. Is there any way I can get more water to fill with certain loads of laundry?
there should be something on the console that says small medium large,that's the water settings.if you have a few things to wash put it on small,large load fill it up on large that's it.
Apr 09, 2011 | Washing Machines
My washer is really loud and is bouncing around the kitchen we have just put new brushes in it as it stopped spinning but thats sorted now its got a mind of its own
Hiya,
Jumping washing machines are often caused by the simple things such as incorrect loading, when you purchased your machine it would have given you a load capacaty, for this machine i think it is quit large but it does have the options of extra settings 1 of which is a half load setting i would surgest you try a half load setting on 1 wash & see if this helps the idea behind this is that if your machine jumps even more than normal then you may be over filling it & if it reduces the amount of jumping then maybe you was under filling it, if the jumping remians the same then we can start to rule out reasons for the jumping.. that would be your starting point to resolve this problem.
Hope this helps
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
Water will only fill up half way when set for a large load and very little water when it's set at medium load.
put less of a load in to compensate the amount of water and save wear and tear on your washer :-)
Jun 22, 2009 | Westinghouse Washing Machines
Washer will not fill all the way.
you may have to adjust/replace the water level switch. it is located behind the control panel. the water level knob is attached to it. it does have a screw adjustment.
May 15, 2008 | Roper RAB2121KW Top Load Washer
Amana ALW480DA Top Load Washer Logo
485 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
