Question about KitchenAid 24 in. KUDP02CRBS Stainless Steel Built-in Dishwasher
Dishes on top rack not clean. appears water not getting up there. now lower rack also...seems like low water pressure?
    President:
  • 949 Answers
This could be due to debris in the sump area. I have put together some instructions on cleaning this area. Follow the link and let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on May 10, 2010
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
The dishes are not getting clean on the lower rack even after several washes. What can be done?? The top rack comes out clean. It almost seems that the water flow on the lower rack is limited. Something as...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
May 10, 2010 | LG LDF6810ST Stainless Steel Built-in...
The top rack of dishes are not getting clean. I
you need to check the upper wash arm for blockage from debris,if this is not the case,then you need to replace the water conduit from the lower sump area to the top arm,after time the water erodes the plastic conduit especially where it connects at the arms and water gets by these areas and can no longer build pressure to spin the wash arm
Apr 19, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Top shelf dishes are not washed
possibly low water pressure...
racks might be in backwards if it's an older model with wheels on shelf system... rubber bumpers should face out...
could be a blockage in the upper sprayer arm... or the upper arm had come off and was remounted in a position that doesn't line up with the jet of water from below...
could be bad loading technique... sounds simple enough but you should never put large bowls or pots that lay horizontally on the lower rack because it really screws up the cleaning effectiveness. Large items should always go on the top rack or be washed by hand if they don't fit on the top rack.
Sep 02, 2009 | Whirlpool Dishwashers
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Dishwasher not cleaning dishes on top rack
Check the riser tube coming from the pump assembly and be sure it isn't blocked or that something else isn't obstructing the pump intake area. Make sure the upper wah arm assembly isn't excessively loose on the spindle and losing pressure because it's leaking. You may have to remove the lower rack, lower wash arm and cover to see.
If everything is clear, it could be a worn or damaged pump impeller. If the machine drains normally, it's not the motor.
May 16, 2009 | Dishwashers
My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Dishes not clean
There may be a couple of solutions to your problem. First, if you are not rinsing the dishes thoroughly before loading, your sump area in the bottom of the machine will get clogged, thus preventing enough velocity to reach top rack. Second, and most likely, your water inlet valve (or solenoid valve) is restricting. You have a timed fill mode through the timer and if the valve is not opening fully, you do not get the proper rate of flow into the machine. Replace the valve and your problem will most likely be solved.
Dec 01, 2008 | Maytag MDB7100AWB Dishwasher
KitchenAid 24 in. KUDP02CRBS Stainless Steel Built-in Dishwasher Logo
214 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
