Question about McCulloch Garden
I have a MAC 3200 chain saw. The primer bulb has split and needs to be replaced. Can you help with a part number and where to buy? I found this: McCulloch Part Primer Bulb 224242Will that work for the MAC 3200?
    President:
  • 2,220 Answers
Howdy Ben;
If the model number is 11-600032-32 and I think it is that is the correct primer, pn 224242-02. OrderTree says NLA. It is available through an "arinet" dealer.
I found one at M&D Mower
http://www.m-and-d.com/index.html?id=o8T9mnhG
$3.96 plus shipping and handling.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 10, 2010
Chainsaw leaks petrol, after putting on chain
replace the primer bulb as it is split or the hose to the carby is split
May 25, 2016 | Garden
How do I replace the primer bulb on an Echo cs-346 chaln saw?
The part number is 12318139130 and this youtube video covers this part's replacement.
http://www.youtube.com/watch?v=cnzag2RqhRo
Jul 12, 2014 | Echo Garden
The saw s primer bubble split ...i replaced the primer and it ran fine..then just quit... i changed the gas and checked the plug for fire .its ok..........but it will not fire ????
I would see if you have a air pocket in your gas lines.Try removing plug and pumping primer bulb until you know engine is flooded. Then let dry out before you put plug back and try to start. Thank you.
Apr 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Poulan chainsaw primer bulb replacement
You can find replacement parts on amazon, here Amazon com poulan chainsaw chain parts. I hope this was helpful. Cheers
Mar 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to replace the primer bulb for a McCulloch 3200 Series, 32cc chain saw. How does it come off?
They either have a spring metal clip behind the case, or plastic prongs that need to be compressed from behind to release it. Make sure the new bulb pumps fuel from the carburetor and back into the tank.
Dec 29, 2009 | Garden
Show diagram of fuel lines to carb for mac 3200
There is nothing available to the general public that provides what you ask! If service manuals exist they may not have the detail you seek!
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple. On the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I’ve found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operator’s Manuals: are much more difficult. I’ve dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it!
I cannot find an IPL for a 3200. Some fuel components, part numbers and a little detail can be found below:
An IPL (Chinese Mac, exploded parts list) can be fond here:
https://www.dixiesales.com/ipl/327/Chainsaws_32cc-35cc.pdf
You may also find the following helpful:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Typical fuel system:
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Nov 20, 2009 | Garden
Need to remove & replace primer bulb on mcculloch mac 3516
There are 4 different IPLs for this saw. Fuel detail are on multiple illustrations.
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
A helpful video, a few of my suggestions, and a schematic follow:
HTH
Lou
Nov 15, 2009 | McCulloch Garden
Fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Aug 23, 2009 | McCulloch Garden
Garden Logo
483 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
