Question about GE Kitchen Ranges
How do I tell if the thermostat is bad or the ignitor is bad for my GE oven JGBS07 EV1WW
    President:
  • 949 Answers
The way to tell for sure is to take an ohm reading on both and a current reading on the ignitor. The thermostat should read 0 ohms when calling for heat. The ignitor should read some resistance but not an open circuit. The current draw through the ignitor should be about 3.2 Amps, any less means it is too weak to open the gas valve.
If you do not have meters try these checks.
If the ignitor glows at all then the thermostat is good. If the ignitor does not glow at all it could be either the thermostat or the ignitor,
If you can see the ignitor close up sometimes you can see a white spot on it or a crack, this means the ignitor is bad.
If you have to guess which one the smart money is on the ignitor being bad
Posted on May 10, 2010
Testimonial: "Thank you. I appreciate the opportunity to save a lot of money and fix it myself. We are not in a position to pay for a service person. God bless, Curt"
Why doesMy GE gas range broiler and oven not ignite?
When my oven had this problem it turned out that the ignitors for both the oven and broiler had gone bad - yep, both of them. You can tell when an ignitor is bad if it doesn't glow as the oven is started.
I posted some pictures here (I think my answer is #10):
Check out this solution to the GE Profile Spectra JGBP90 Gas Kitchen...
Of course the design of your oven might be different but I suspect the repair would be very similar. Regardless, check to see if the ignitor is glowing.
Jul 08, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Feb 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas oven spectra xl44 takes forever to preheat &sometimes will not
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Will all that said, more than likely the ignitor is bad in the oven, not drawing enough amperage to allow the safety valve to open. Even though the ignitor is lighting up and glowing, I'm 99% certain that this is the problem. Here is the part number for ignitor. WB2X9154 and can be ordered from any parts distributor or from a local supplier.
Jun 21, 2012 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a JGBP31 oven WEC3WW. The oven pilot light went out How do I get it lit again?
Greetings,
This oven if not mistaken has a round ignitor that glows red to lite the burner.....most of the time this is what happens...this is what you need to do...if by any chance you have a volt/ohm meter, follow the ignitor wires to a place where they come to a plug or some sort of power connection...place your meter probes one on each wire going to ignitor and turn on the bake..be careful not to shock yourself and see if you have line voltage 115-125 volts if so and its not glowing...its bad...if no voltage, then you may have a bad sensor, or wiring problem or control or thermostat, but most common is the ignitor
Bruce Denton
Dec 13, 2010 | GE Ovens
Oven ignitor won't ignite GE RANGE : JGBP28DED1CT
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jul 14, 2010 | GE Kitchen Ranges
No broil or oven cook top works
try checking the ignitor or the thermostat in the oven.
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont light
Mine did that and I found the ignitor for the oven was bad. It was the "glow" type for pilotless ignition and it was burned out. It is supposed to glow bright red and the gas comes on and the oven will light. It was easy to tell that it was bad. But to check it I swapped the broiler ignitor with the oven ignitor and the oven worked.
Dec 20, 2008 | GE JGBP33SEHSS Stainless Steel Gas Kitchen...
GE Spectra stove, oven won't light
Hi ewood,
You can look up your ge owners manual at ge.com . If the oven has stopped working chances are you have a bad ignitor. the part number is WB2X9154 . The part is $69.99 and I have this item in stock. Shipping will be $6.50 in the continental US>
I hope this will FixYa. If you have more questions please let me know. I can tell you how to remove the old ignitor if needed.
Anderson Appliance
Mike Anderson (Owner)
(865)945-3808
Sep 30, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven shuts off by itself
When your oven reaches the desired temp. it shuts down then turns back on again after it cools down a couple of degrees and cycles like this during the complete baking cycle. If your ignitor or oven valve is getting weak it would cause this symptom.
Oct 31, 2007 | GE JGRP20 Gas Single Oven
Kitchen Ranges Logo
320 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
