Question about Fiesta Advantis 3000 Grill
Flames periodicly coming out bottom by hose going totank getting
Flames periodicly coming out bottom tank getting hot
  • Fiesta Master
  • 2,514 Answers
Then you have a gas leak needs to be fixed unsafe to use try soap water on joints to trace leak when on
Posted on May 17, 2010
BBQ does not get hot enough to cook properly. All gas jets are clean as BBQ is almost new
blue flame? if flame is not blue, then air gap needs adjusting. if blue flame and burner control is on high, then could be your regulator. (assuming tank if full)
Apr 17, 2015 | Grilling
Tip
Gas Grill Won't get as hot as it used to? Read on:
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
on Mar 19, 2010 | Grilling
2 yr old baby Q new tank was able to get very litle flame then nothing tryed with lighter checked connections Tryed a used mini tank no go The snow is about gone here and would like to get her...
The LP Grill tank's OPD Valve has locked up your regulator. To solve the problem turn the tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Reconnect the hose and turn the tank valve on VERY, VERY, SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner and turn it to high. Does the flame height now look correct? If so, you solved the problem.
If it didn't and the grill and tank were stored outside during the snowy winter. The grill's regulator may be frozen. In which case, soak a bath towel in hot water, ring it out and quickly wrap it around the regulator. If that was the problem, gas should start flowing again, in several minutes.
Hope this helped to solve your problem.
Apr 03, 2011 | Weber Grilling
How to put new gas line from carb totank
Cut the new one at an angle like to a point then run into the tank take a wire ( I use a short piece of coat hanger with a U bent in it) and fish the line out put on the filter then drop the filter back in the tank with plenty of line so the filter is at the bottom of the tank then run the line to the carb and cut any excess off and put on carb
Feb 12, 2011 | Poulan 25CC Gas BlowerVac
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Grill lights but flame is low and goes out if control is moved from high. Burner tube is clean, spider screen is clean, and I have a full tank of LP. Grill is Q series about 1 year old and has been working...
Mar 22, 2010 | Weber Q Grill
My burners don't put out out much of a flame. Model CGBD48RSBX. Ten years old. Can I clean them?
Hello. Clean them with a wire brush and a shop vac. And, read on: re you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
Mar 21, 2010 | Grilling
Grill wont heat as it did
Mar 19, 2010 | Weber Q Grill
Need owners manual, Perfect Flame Grill, Model #E3520-LPG
I have a perfect flame gas grill E3520LPG and it takes a hour for it to heat up
Apr 11, 2009 | Grilling
Fiesta Advantis 3000 Grill Logo
71 people viewed this question
Top Fiesta Grilling Experts
paulcarew
Dan Webster
Dan Webster
Lawrence Oravetz
Are you a Fiesta Grilling Expert? Answer questions, earn points and help others
