Question about Casablanca Fan Casablanca AVIO by Macrosystems
The hard drive space is 15% used, but after recording 2 minutes a pop up insists the harddrive is full
    Problem Solver:
  • 15 Answers
Try clearing recycle bin and temp folder. sometimes recording is not compressed and takes up much more space than is actually necessary. make sure ur video recorder is set at the approriate compression format. anyway this requires more info like how big is ur hard drive?
Posted on May 10, 2010
Funlux surveillance hard drive issue. 1 tb, is full, need formatting , it takes 5 minutes plus to format. Every 2 minutes it reboot, trying to record, won't finish formatting. Disconnected cameras,
You did not post the model of the unit. There is a port for external drive support and there is an internal drive depending on the model. You can try formatting on a computer if you would like or you can select OVERWRITE recording when the HDD is full
1. Access the [General Settings] and open the [Disk Drive Info] page. 2. Open the drop-down menu at the top next to the "Hard Disk Drive Full", select "Overwrite" and press save.
Jan 07, 2017 | Hard Computers & Internet
Bought a tvonics freeview dtr-hv250 digital tv recorder, keeps coming up but it wont allow me to record. keeps saying the hard drive is unformatted. done what it says on the on screen instructions but
Go to your on screen menu under dtr settings and format the hard drive. If you have been recording the hard drive may be full and some programs need to be deleted to allow more recording space. You may also unplug the unit for several minutes and use the reset box option.
Jul 28, 2016 | TVonics Televison & Video
Which hard drives are compatible with aspire e380
Up to a 400GB SATA harddrive.
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE380/AspireE380sp2.shtml
These are examples of SATA harddrives,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=139&name=Serial-ATA-Hard-Drive&
Note* Suggestions
When buying a harddrive it is best to,
1) Look for the right amount in size, but also look for one that has the largest Buffer.
The Buffer is the cache for a harddrive.
The buffer area is a small memory area.
It is the first memory area the device looks for.
The larger the Buffer, the faster the harddrive will be at gathering, or giving information.
2) Spindle Speed:
Normal spindle speed has evolved to 7200 RPM. (Revolutions per Minute)
Older harddrives were 5400 Rpm, and even slower.
There are newer harddrives out with much faster spindle speeds. 10,000 rpm on up.
Unless you are a full time gamer, with wanting to have the fastest computer possible around for gaming, there is no need for a harddrive faster than 7,200Rpm.
[If you are not aware of how an average harddrive's mechanical makeup is constructed;
Inside the harddrive case are Platters. These Platter's resemble CD disks, and are constructed of highly polished metal, or glass.
The Platters rotate on a Spindle. The construction is akin to a record on a phonograph.
There are 3 to 6 Platters, and maybe more with newer harddrives.
EACH Platter has a ReadWrite Head above it, and Below it.
The Read/Write Head does just what the name implies. It reads information off of the Platter, and can write information to the Platter.
Each Read/Write Head is attached to an Arm. The Arm sweeps the ReadWrite Head across the Platter.
When the harddrive is operating at full capacity, the ReadWrite Head can be moving across the Platter, at Hundreds of Times a Second!
The Read/Write Head is located above the Platter at a distance, that is around 1/6th the thickness of an average human hair.
(Approximately .0005, or can be said as 5 ten-thousandths of an inch. An average human hair is .003 thick. {3 thousandths)
Between the distance from the Platter, and the fast movement, there is a cushion of air formed in-between the Read/Write Head, and the Platter.
The Read/Write Head literally floats above the Platter.
The Platters are coated with a magnetic media. In otherwords this media can be magnetized.
The Write portion of the Read/Write Head arranges this magnetic media in a pattern.
The pattern is a series of 0's and 1's.
Zero being Off.
One being On.
More information about harddrives can be found here,
http://computer.howstuffworks.com/hard-disk.htm
3) If your SATA harddrive comes with a 4-pin Peripheral power connection, AND a SATA 15-pin power connection, ONLY use the 15-pin SATA power connection!
I will give a link to both the 4-pin Peripheral power connector, and the 15-pin SATA power connector in an additional comment.
Apr 22, 2010 | Acer Aspire E380-UD420A (ASE380-UD420A)...
5T020h2 jumper setup
No jumper is used on the J50 pins, when using the Maxtor 5T020H2 IDE harddrive, as a Slave harddrive.
In otherwords do not use a jumper on any of the jumper pins.
This is a PDF file of the Harddrive Specifications of the 5T020H2, 5T010H1, 5T030H3, 5T040H4, and 5T060H6 Maxtor IDE harddrives,
from Seagate. (Seagate bought out Maxtor)
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/dm_plus_60_ultra_ata_manual.pdf
The Jumper Settings are in Chapter 2, Page 5 (2-5)
Looking at the page number for the PDF file it's on Page 15.
Oct 07, 2009 | Maxtor Hard Drive
My D: drive is 99% full how do I free up disk space ?
Music, video and pictures use the most hard drive space. Store them on a disc or on line storage site. After the delete or removing as advised, defrag you hard drive. This should free up space. Get rid of any programs you don't use. As long as you don't delete hidden files you should be fine. Hope this helps. If you are using windows XP go to start, control panel add and remove programs and delete only the programs that you installed and remove only them.
Jun 21, 2009 | Compaq Presario Notebook
My 500GB Lacie harddrive says it full too
Way too little information to solve this problem. Operating system and connection type are good places to start. errors if any during installation, startup, or during connection also would help. format type and OS format type and if it was previously used on a different type of system like mac to pc or linux/unix.
Jun 19, 2009 | LaCie (300770) 250 GB Hard Drive
Harddrive has no Total size and Free space on my windows explorer
yes, probably this can be solved.
does the harddrive still have a letter assigned?
if so. go into command prompt (start->run->type"cmd")
when the black window pops up write:
chkdsk x: /r (where x is the letter assigned to your 120gb disk)
please reply if your harddrive doesnt have a letter assigned.
May 29, 2009 | Seagate 1 TB SATA II Hard Drive
How to partition harddrive equally
Use a program called Partition Magic
Apr 11, 2009 | Samsung Q45 Notebook
Harddrive space problem.
When the HDD was fornatted, was it formatted appropriately? It's quite possible to format a 160GB HDD to present a smaller amount of space.
Mar 08, 2009 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
Dr-mh30s. stops dubbing after a few minutes.
I seem to have sorted this problem for me simply by unplugging power.
I actually left it for nearly a week before plugging in again, but I'm sure a day would do, probably less.
Dubbed 2 playlists since, no problem.
Nice simple solution if it works.
Feb 22, 2008 | JVC DR-MH30S DVD Recorder
Casablanca Fan Casablanca AVIO by Macrosystems Logo
81 people viewed this question
Top Casablanca Fan Televison & Video Experts
deton8 von Splosion
Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
