Question about GE PFSS6PKSS
GE PFSS6PKW Displays 8888
After a 3 second power outage, my GE model pfss6pkw is now showing 8888 on the display and I can't reset it. I turned off the power to the refrigerator for about 8 minutes and turned it back on, but the display has not changed. How do I reset it, or what does it mean?
Thanks
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel.
Posted on Apr 11, 2011
    Problem Solver:
THANK YOU THANK YOU THANK YOU. This was the easy fix! Other sites were telling us we had to get service to replace the logic board. This was the cure for my Samsung model RFG298.
Posted on Dec 28, 2014
How to reset Panel for PFSS6PKW bottom freezer GE Profile Refrigerator? When power went off display is just showing 88 88.
Try pressing and holding the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 or 15 seconds. It should give you and audible beep and reset the panel.
Oct 16, 2014 | Refrigerators
Ice maker freezes up
Replace temp sensor in freezer and main control board
Nov 06, 2013 | GE Refrigerators
Ge profile bottom freezer
i used a turkey baster to blast hot water through the drain to the pan took a few tries but it worked. sucked up all the old water first then gave it a good hard shot.
May 16, 2013 | Refrigerators
GEProfile model #PFSS6PKW icemaker knocking
There are no serviceable parts on that ice maker and it will need to be replaced if you find it to irritating. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 18, 2013 | GE Profile PSW26P Stainless Steel Side by...
How do i remove the ice shoot on my ge profile model# pfss6pkw
pop the control panel off by taking a thin blade knife at the bottom of this panel and prying out on the two edged of it,then unplug the wire harnesses to it,then remove 4 phillips screws behind it remove the paddle assembly,dont lose the little spring on the paddle
Nov 04, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 01, 2010 | Hardware & Accessories
GE PFSS6PKW display shows "88" on freezer side and
my fridge had the same prob thank you very much this really works i pressed the energy and alarm for 10 seconds and works PERFECT
Nov 15, 2010 | GE Refrigerators
GE PFSS6PKSS Logo
1,392 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
