Question about Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting
Blower will run on choke but not in the run postion
    Sniper:
  • 53 Answers
If you haven't tampered with any adjustments (Set screw, Idle, Hi or Lo jets etc...) then most likely your carb is flooding. You either have something stuck in the needle valve passage keeping it open. (And it can be Tiny! and I mean a speck.) You can try shooting some good old "Gumout" or any other carb cleaner/ degreaser made for carbs. Try removing the gas line off the carb "Inlet" and with that hose off spray the carb cleaner into that hole liberally. Pull the throttle open and close fast as you do the "spray in".If you have compressed air? Send a little of that in there after the spray, then spray a bit more cleaner in. Let it then sit for 10 15 min loaded with cleaner. Then reconnect the gas hose, prime it up with the primer bulb, restart it, let it warm up a bit. see what happens. Oh FYI to much oil (or the wrong type)in the gas mix can sometimes cause something very similar to flooding. So make sure all is correct!
Posted on May 10, 2010
Sears snow blower runs rough like the choke is on
put in injector cleaner in gas
Dec 14, 2013 | Garden
MTD SNOW BLOWER WON'T RUN WITHOUT CHOKE ON
If it will only run on full choke you have an air leak somewhere
Jan 21, 2013 | Garden
My homelite blower starts but after on run position shuts down
Ck and see if it has a choke. If it is on full choke, reduse choke after you put in on full run.
Oct 05, 2011 | Homelite 'Yard Broom' Leaf Blower
Choke when set it will not releas or open back up. I can open choke by pressing in the tab that holds it closed and it pops back open
try holding throtle in the wide open postion and it releases the pin .adjust the choke with throtle in the full throtle postion
Aug 13, 2011 | Tomos Sprint Motorcycles
Blower will only run on full choke ryobi ry08578
They aren't designed to run with full choke on, the choke is for starting cold engines only, many times you can choke them pull the cord a few times and then turn the choke off or turn it down to start it. Then slowly reduce the choke until it runs fine on its own.
May 06, 2010 | Ryobi Backpack Blower 25.4cc
Runs but choke still close, or pull out postion
You can start with the choke closed but you must open it up once it start running.
Sep 25, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Start, but don't stay running
ok starts how long?
and is this after pumping the primer? also choke postion make sure you change it after it starts right away and make sure look under air filter to see if choke is closing when operating choke.
Apr 16, 2009 | Craftsman Garden
Snow blower is running sluggish with the choke in the on position
It sounds like you my need to rebuild and clean the carburator. Or you have an air leak between the carb and the cylinder.
Jan 28, 2009 | Toro Blowers Rake and Vac - Electric...
Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting Logo
434 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
