Question about Cycling
I have kit, but no instructions on how to repair a bike tube. help please.I have bike tube repair kit with patches, glue and metal things
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
The metal thingy is used to roughen up the tube, where the patch will go, so the glue will stick. The glue may have instructions on it, but place glue onto the patch and the tube and let it dry for a few minutes, then place patch over hole.
when refitting the tube, sprinkle some powder on it around the patch and inside the tyre, make sure you have removed whatever caused the initial puncture. Try to refit the tyre without using any levers, so you dont pinch the tube again
Posted on May 10, 2010
How to Patch a Bicycle Tube?
buy a new tube.
Pull out tube
Pump air in to it
put under water
notice were are leaks from
using a bicycle patch kit
sand tyre around hole
glue patch over hole
wait for glue to set
check no nails, glass embedded in tyre first before you
put tube back inside tyre
put tyre back on wheel
https://www.youtube.com/watch?v=x5x7GIc0e6g
https://www.youtube.com/watch?v=WG7Y1eSDsNA
Oct 20, 2016 | Cycling
Can you repair sevylor bladders? if so how?
dollar store contact cement in tube., an old bike tire, cut a patch out of tire and glue the patch on glueing around hole and underneath patch. apply patch smoothly. now glue around edge of patch. and let it dry for a few days at least 24 hrs. I have patched a bic yakka and a few cheaper inflatables patches hold up and hold air. good luck.
Aug 30, 2012 | Stearns SEVYLOR Sit on Top Kayak U250
Repair hole
i use cheap contact cement (dollar store tube works fine) and a bike tire inner tube (much better than crummy patch the give you) and apply some glue around hole and on bottom of patch, apply it smoothly, and aplly glue around edges (seams ) of patch. let dry for 2 days, if your using the transparent patch its like a sticker peel and smooth it on and let it dry for 2 days( in my opinion and experience they ****)
Mar 18, 2012 | Sevylor 2 Person Sit On Top Kayak
How do you fix a leak in a towable?
get a patch kit at walmart or any lowes..it comes in a kit w/glue and sometimes a patch..follow the instructions. glue then put patch on ..use the right time in instructions though
Aug 16, 2011 | Sport & Outdoor - Others
SMALL HOLE BOTTOM OF 15 x 4 metal frame pool. believe a small pebble caused it. water leaking out is there a way to save the poolwithout draining and taking it apart?
Try this....
You will need;
Pool liner patch kit
Goggles
Body weight to hold you down while doing repair under water.
Most liner repair kits have instructions on wet applications. Cut a piece of the liner kit fabric to cover the entire hole plus at least 1/2" around. You will need to dive in with a mask/goggles to see the hole. Put a thin layer of glue on the patch and spread evenly.. Fold in half on the glue side and go down to the bottom of the pool. Note...The weights will help you stay at the bottom for this part of the repair.. QUICKLY!!! while holding the patch next to the hole. open the patch and place on the hole and push firmly for a few seconds. Come up and place your foot on the patch and hold for 3 minutes or so. Should work...It took me several times to master this technique when I had a hole at the bottom of my pool... Caution!!! You don't need a lot of weight to stay at the bottom. Test from light to heavy until you think you have enough to do the repair..
Good luck and hope this will help you!! If this works for you, please rate!
Jul 19, 2011 | Intex Easy Set Pool 15x36
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
How do you fix a leak to a 15x48 swimming pool without emptying all the water? it's a small leak on a seam near the ground.pool has been up a week & no leak, until tonight?
They make underwater patch kits that are very simple to use. You cut a patch and apply glue, fold the patch in half with the glue faceing in. take it to the leak and slowley unfold against the hole. smooth out and make sure edges are sealed down. Keep pressure on the patch as instructed on package. Then let cure. Good luck.
May 28, 2010 | Intex Ultra Metal Frame Pool w/ Upgraded...
Small rip in treadmill belt
No really. You need to replace the entire walking belt. Not to hard of a job and most replacement belts come with some instructions. We use www.treadmillpartszone.com for parts.
Apr 10, 2009 | NordicTrack E4000 Treadmill
How to repair a flat tire?
hi!
to find the hole, try to fill the tire with air, and put it on a shallow water were it's enough for you to see the bumbles that come out from the tire.
to repair a flat tire, take out the interior of tire and if you happen to see the location of the hole try to find an unused rubber and cover the hole with that rubber and glue it with a quick drying glue... (this is a non-professional work)
Oct 29, 2008 | Bell Sports #1002016 26" Mountain Bike...
Cycling Logo
113 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
