Question about Tricity Bendix AW850W Front Load Washer
I need a counter weight 4 a tricity 800 front loader washer
  • 269 Answers
I am not sure if its the front or rear you want but here are the genuine Electrolux part numbers and prices.
Front weight. 1260582109. € 36.99 + vat.
Rear weight. 1260399207. € 21.50 + vat.
If you get in touch with Electrolux they should be able to help.
Hope this was helpful.
Good Luck.
Posted on May 10, 2010
May tag front loader has loose screws behind doors
Did this problem recently start is the model number I am reading correct MFW9700 front loaders are hard to unbalance due to the fact the control will stop the spin and reverse direction in an effort to redistribute the load on a concrete floor which is smooth the high RPM's in spin will cause it to walk I have seen more broken counter weights than a broken shock this will definitely cause it to shake like crazy again my thought process is that the machine has previously worked in the same location
Apr 12, 2014 | Maytag EPIC MFW9700S Front Load Washer
Tricity aw 1000 front loader washing stuck in will not open
Does the y splitter have little valves on it? Make sure both are open.
Nov 28, 2013 | Tricity Bendix AW1000W Front Load Washer
Can i get a manual for bendix wd-1054 bx washing machine?
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 27, 2011 | Tricity Bendix AW1000W Front Load Washer
I have a Fridiare front loading washer. Water comes in fine and is pumped out but washer will not spin. Tried to spin by hand and wont budge. Any ideas?
Pull the unit out from the wall and unplug it. Remove the back panel and check the counter weight, spider pulley and belt. The counter weight is attached to the top of the drum and is known to loosen and fall to the bottom of the unit damaging the spider pulley. If the counter weight is attached to the washer drum and the belt is attached to the spider pulley and motor than you will need to check the voltage on the motor. If you do not have voltage to the motor than the control unit may be defective.
Nov 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Need a timer and where do i get it from for a bendix front loader l105rx
Look up SERVALL for your closest location. Or from an appliance parts distributor. All you need is the model# and what it is.
Aug 22, 2010 | Tricity Bendix WDR1040W Front Load Washer...
What is the quickest wash cycle for the tricity bendix wdr1040w front loader
This is relating to the 2006 model.The times are not printed in most manuals like they used to but on this machine most probably the quickest prog. would be( 4 ) this is 3 rinses and a long spin at 40 deg. If you are experiencing long times on your washes do check that your water pressure is good as that will shorten the duration of all cycles and save on electric.
Good Luck
May 04, 2010 | Tricity Bendix WDR1040W Front Load Washer...
The drum spins wildly out of balance to the point that it wears away the hard white plastic shield at the front. Is there some alignment guide that may need to be adjusted
this is usually caused by uneven loads. if your sure the the loads are evenly balanced check under your washer for loose or dropped parts
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
How do I replace my boot gasket on my Bosch Nexxt washer?
Here is how you do it. 1st remove the door & hinge, 2nd remove the covers on the screw where the door sits that holds down the control panel. 3rd remove two screws holding the door latch in place. Remove the spring & wire holding the boot on and pull the boot loose from the plastic holder Remove the plastic boot holder. You will now see the boot where it attaches to the tub. There is a spring and wire that holds that on. At the top there is a tab on the seal, grab it and pull towards you. The boot will come off. To reassemble I remove the counter weights(concrete weights) from the tub and put the boot firmly into the slot on the tub. Now reinstall the rear spring. Be sure to also reinstall the counter weights if removed and torque them tight around 25 to 30 foot pounds. Reassemble the front panel and put the spring retainer back on. Tools needed T20 torx driver, 13mm wrench, and needle nose plyers.
Aug 09, 2008 | Bosch Washing Machines
Tricity Bendix AW850W Front Load Washer Logo
71 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
