Question about Sony Handycam CCD-TR618E Camcorder
I have a Sony Handycam CCD-TR61. It has worked fine until today. It will not accept a tape. If I close the door without a tape, it closes and completely shuts like it is supposed to. But, if I put in a tape and close the door, it pauses and then ejects the tape.
2 Suggested Answers
  • 37 Answers
SOURCE: Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
Posted on May 20, 2010
Sony video handycam ccd fx420
The take up spool is no longer working. Time for a new V8 machine.
Jun 10, 2017 | Video Cameras
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
I have a Sony Video8 Handycam CCD-FX340 NTSC. It will not accept a tape. I can hit the eject button and the tape mechanism will come up and pop open. If I close it without a tape, it will go back down....
This problem can be caused by condensation. Leave camera and tapes in a warm dry place for a day and try again. If that doesn't help, there may be a tape threading fault. This can be something as simple as a broken drive belt, but still will require professional attention.
Oct 28, 2010 | Sony Video Cameras
I have a Sony Handycam CCD-TR61. It has worked fine until today. It will not accept a tape. If I close the door without a tape it closes and completely shuts like it is supposed to. But if I put in a tape...
Many times it's a belt slipping. Since the tape isn't pulled into position, it's rewound and the tape ejected. A damaged or mal-adjusted switch could cause this too. The most you can do is blow it out with compressed air to see if that helps. I doubt there are many thing the end user could do.
Oct 29, 2017 | Sony Handycam CCD-TR618E Camcorder
or a sensor ...
regards Alan
May 18, 2010 | Sony Handycam CCD-TR618E Camcorder
My sony trv37 cassette door won't close.
If this condition only occurs with as cassette inserted to load this may indicate a condition where the cylinder which holds the video heads is not spinning up when requested by the system control microprocessor.
If the door will not latch closed with/or without a cassette inserted this can indicated a mis-timed condition of the tape loading mechanism.
Try closing the door without a cassette loaded whilst the unit is powered from its AC Adaptor - under certain conditions this may allow the mechanism to reset and may allow the door to then close.
I trust that this information is of assistance! RHN
Jan 02, 2010 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Dec 04, 2009 | Sony Handycam CCD-TR64 Camcorder
Tape door wont close on my Sony CCD-TR416 camcorder
Try this for anyone having this issue:
HERE'S WHAT WORKED FOR ME PER SONY TECHS:
Take? OUT the battery or disconnect the AC cord.
Turn the camera ON (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
VOILA!
Worked for me and I had the stupid C32:11 error code for weeks! Door would not close. Followed the SIMPLE and SAFE instructions and IT WORKED! Just like magic. I couldn't believe it! Save your money TRY THIS!
Sep 22, 2009 | Sony Handycam CCD-TR416 Camcorder
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Sony Handycam CCD-TR618E Camcorder Logo
159 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
