Question about JVC KW-NX7000 Car DVD Player
My unit wont turn on it worked when i turned it off and now it wont do anything but eject a disc or detach the face plate
  • link_44s May 10, 2010
    If that doesnt work what then?
    President:
  • 4,070 Answers
Hi! Please try to do this. Open the hood and remove the battery connectors. Let it sit for atleast 30mins, this will reset the system and can get your unit back to normal running. Put the battery connectors again and turn the unit on and see if it worked. Hope this helps and have a good one!
Posted on May 10, 2010
  • dj_relly999
    dj_relly999 May 10, 2010
    If it doesnt work I believe that the problem is internal. It could be the board or blown capacitors. This what makes it work. You will need to replace them just incase.
What does DCP stand for?
[Detachable Control Panel].. Which is your face plate.. I take your having trouble , remove all disk USB mpe attacehed remove face plate you will see a little hole you will need like a paper clip to push the button for about 2 seconds to reset the unit. after resettting attach face plate and try unit.
Feb 25, 2014 | Clarion CX609 Car CD/ MP3 Player
My 9855 alpine will work when you take the face off / and put it on but the buttons don't work but you can control it with the remote,and when you hit the eject the face wont come down and it wont eject a...
had the same problem with my alpine, i was able to fix it once by, popping off the face plate and with fine grit sand paper (lightly) sand the connection points on the radio and the face plate, then put a little bit of dialectic grease on it . also doing a reset on the unit helped me from time to time...
May 02, 2010 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Just installed an XDM7615 Dual stereo and the face plate won't detach. Can anyone help? The manual says there is a button behind the face when it's in the 'eject' position but pushing this button does...
There are 2 very small screws on the back of the face plate that need to be removed. Once these are removed, you may then remove the face plate.
Feb 10, 2010 | Car Audio & Video
My Dual XDM7615, will not even shut off and no buttons will work at all, it wont open or change stations and only plays radio on a station that sounds like AM,remote controll has new battery and wont even...
unplug the reciver from the back of it and wait for 20 sec. and plug it back in, this should allow you to eject. now turn off your car and jush eject, when it opens to eject's push the release button on the back of the face like your removing it but instead force the face to completely go down, as far as it will go. now turn your car on and put a cd in and see if that works for ya.
Jan 24, 2010 | Dual Car Audio & Video
The detachable face plate opens up when i turn off the ignition
This is a option you can disable in the menu, it is meant to make it easier to detach the faceplate when you leave the car
Apr 12, 2009 | Pioneer Car Audio & Video
Pioneer 7800MP can't turn on
It looks like the flexible cable worn out. Try to replace the cable.
This link may help:
Intermittent display on Pioneer DEH-P7800MP car audio
Mar 24, 2009 | Pioneer DEH-P7800MP
DISC STUCK AND ERROR 02 MESSAGE
hi, i have a kenwood kvt_725(or did have before some scallywag robbed it) i had a simular problem when ejecting discs i found that if you turn power off and removed face plate and turned ignition off it eventually ejected the disc and worked, or a simular routine with the face plate then ignition etc etc. i know it seems a lame solution sorry but hope it helps.....
Mar 20, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Ps3 jammed disc
Unfortunately their is no step by step or guaranteed method to fix this. Here are a few things you could try: turning it off and on, press/hold the eject button, resetting while holding the eject button, shaking or tapping it a little while trying to eject it, holding it different ways ex. face disc opening down towards floor while gently tapping and pressing the eject button. Essentially do whatever you can to get the disc to jar loose, >but whatever you do, don't for any reason stick anything in the slot or try to open the case <Doing this will void the warranty for sure! If none of these work your last resort would be to return it for a new one (providing you still have your receipt and it's less than a year old) or take it to a costly repair guy.
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
Works sporadically
Sounds like your head unit is on it's way out, you could try cleaning the contacts of the face plate plate with rubbing alchol and a q-tip. Make sure you get both sets of contacts, the face and radio.Because the display is working it's definatly not a power problem, clean those contacts and if still doesn't work invest in a new radio, sorry to bear bad news if it's not the contacts. L8R
Sep 18, 2007 | Alpine CDA-7894 CD Player
EJECTING ERROR/LOADING ERROR
yes, i send it in to alpine and they adjust it for like $100 or so.
Dec 28, 2006 | Alpine IVA-D310 Car DVD Player
JVC KW-NX7000 Car DVD Player Logo
89 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
