Question about Alpine MRP-M450 Car Audio Amplifier
My Alpine m450 amp light is on but no sound
I hooked the alpine m450 amp to where my old amp was and the light only goes on but there is no sound coming out. Would this problem be internally and if there is what would i have to fix?
  • Bibow May 11, 2010
    It seems that your problem is internal, but in order to find a solution I need additional info.
Make sure your RCA's are plugged into the input and not the pass through
Posted on Apr 06, 2008
When the bass cut on the speakers cut off
220 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
the amplifier may be over-driven. are there red protection lights coming on the front panel? Or a loose wire - power, ground, or speaker.
Dec 18, 2008 | Alpine MRP-M450 Car Audio Amplifier
Amp light flickering
do you have a capacitor its like an extra battery, if you turn the volume way up with cvr's pullin big power, it cuts out because theres not a steady flow of power.... hope this helps
Jun 30, 2008 | Alpine MRP-M450 Car Audio Amplifier
Not enough bass
its prolly the deck, did you try turning the alpine's input gain controls up...
its not the wiring, if the wiring was insuficient, it would just melt...
you might also see if you could adjust the bass frequencies or crossover frequency, the crv might just have a different resonant frequency then the rav 4
May 16, 2008 | Alpine MRP-M450 Car Audio Amplifier
Amp light is on but doesn't put anything out to my subs
if you are sure its the amp. the problem is internal. but if your not sure, try a different stereo or source of sound to the inputs of the amp. if there is still no sound than it is the amplifier and it could be a number of things.
Jan 07, 2008 | Alpine MRP-M450 Car Audio Amplifier
MRP-M450 puts out no sound to the subs
The amplifier may be overloaded, check to see if it can handle 4 OHM loads and 2 OHM loads. if it turns off at high volume the amp may be overloaded. if so try a 8 OHM load. if it still turns off it may be an internal problem.
Jan 07, 2008 | Alpine MRP-M650 Car Audio Amplifier
Alpine MRP M450 Problem
Sounds like it is getting too hot and a thermal overheat protection switch is shutting it off. Check to make sure your gain isnt over 3/4.
Dec 05, 2007 | Alpine MRP-M450 Car Audio Amplifier
Alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
Just died out..
Have you determined if the problem is with the amplifier or the subwoofer?
Have you checked the wiring to make sure that there are no loose connections?
Oct 18, 2007 | Alpine MRP-M450 Car Audio Amplifier
Amp not working
my friend your amp could be getting power that does not mean that it is working.the power only goes to certain point but because your regulator or other related component is defected your amp power supply will not work until the defect is corrected.take it to a tech and have your set repaired.good luck.
Jun 11, 2007 | Alpine MRP-M450 Car Audio Amplifier
Alpine mrp-m450 Amp won't stay on
im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
Nov 12, 2006 | Alpine MRP-M450 Car Audio Amplifier
Alpine MRP-M450 Car Audio Amplifier Logo
334 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
