Question about Nor-Lake Freezer Norlake Refrigeration 6' x 6' Kold Locker Walk-In Freezer - 6' 7'' High w/Floor
What tupruture should we keep the free ><_> - Nor-Lake Freezer Norlake Refrigeration 6' x 6' Kold Locker Walk-In Freezer - 6' 7'' High w/Floor
Modle evl201nxrq00 not cold enought to freeze food
I need you to feel the top of the compressor and tell me how hot it is. Also tell me if the condenser fan next to the compressor is running. If the top of the compressor is too hot to keep your hand on top the problem may be the=> 4356738 Start Relay also found here=> 4356738 Start Relay Here is a link to the repair parts list=> EVL201NXRQ00 Repair Parts List You can see the parts listed on page 5 and 6 of the above parts list. Hopefully this is the only problem causing your freezer to stop freezing as well. If the 4356738 Start Relay is defective it will cause the problems by not allowing the compressor to run or start very well also cause the top of the compressor to overheat. You may also need to change the=> 8210224 Capacitor also found here=> 8210224 Capacitor And the=> 2-34286-021 Overload also found here=> 2-34286-021 Overload Feel the top of the compressor first and let me know the results and we will go from there, Thanks Sea Breeze
Dec 05, 2012 | Whirlpool Freezers
On a up right freezer the red light comes on and stays on and everytihng defrost what could be wrong
I want you to feel the top of the compressor to see if hot or too hot to keep your hand on the top. Click Here for a photo of the=> FFU2124D System Components item 30 is the 216649315_Relay-and-Overload-Kit item number 55 is the=> 5304464438 Run Capacitor
If the compressor is too hot to keep your hand on top it may be the=> 216649315_Relay-and-Overload-Kit
Let me know if the compressor is hot and we will know the compressor is trying to start but cannot. Replacing these parts will possibly solve the problem of your freezer being on but not freezing everything, We need to make sure the compressor is running, Thanks Sea Breeze
Nov 28, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer does not get cold enough.will not get lower than 21 degrees. I took some articles off the top shelf so that the inlet could function better,but do I need to find the return air vent and clear it?
All vents should have at least 2 inches clear in front of them. Also>> Is your circulating fan working?
Sometimes they stick or slow down and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ihave a hoover fridge freezer it started freezing the fridge compartment now freezer not freezing and compressor comes on and go's striaght off again
Sounds like your compressor relay switch is bad but feel the compressor and see if it is hotter then you think it should be. That is easy to tell because you will not want to keep your hand on it long. That would mean a possable bad compressor. Please give a thumbs up for my effort. I could help more if I was there. keep me informed though. The Raz Shack
P.S Just for kicks>>>>>
Sometimes they stick and need a shot of WD 40 and then work
Apr 06, 2010 | Freezers
Temperature Alarm beeping/buzzing Kenmore Freezer 26041
Just incase>>>>
It may be slowing down.
Mar 17, 2010 | Freezers
The alarm keeps going off, however it is cold inside and seems to be working. The display had .2.0.5. flashing on it. Any idea. Could it be the 9 volt battery back up?
Thats a good thing to check but also>>>
Mar 02, 2010 | Continental Freezer Reach In Freezer Three...
Woods freezer yellow light looks light a snow flake wondering what that means
Does it sound like it is never shutting off/ It may mean it is over freezing. Also for good measure >>>>
Mar 01, 2010 | Woods 4.3 cu. ft. / 122 liter Chest...
Temperature alarm keeps beeping - we had a repairman today come and clean out the drain and it was fine until tonight -now it is beeping again.... our model # is 25321041104; serial # WB21617872,...
Just a guess but for good measure>>>
Feb 20, 2010 | Freezers
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Jan 05, 2010 | Freezers
Top part of upright freezer not freezing and bottom part collecting ice.
check for food blocking any vents and for good measure>>>>
Jan 04, 2010 | Freezers
Freezers Logo
Top Nor-Lake Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
