Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
There is a white film on dishes after the cycles end
It seems to be getting worse. Have tried less soap jet dry, vinegar etc...nothing is working.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.You will love this product.
Posted on May 12, 2010
Built-in dishwasher. dishes not clean, plus nasty white residue on everything...
Hi
The white residue is from the new environmentally safe soap. Check your soap and see if it is phosphate free soap and that will be your issue. Also either you have hard water or you're seeing either calcium or lime deposits. You should use the jet dry for every load. There should never be any suds in a dishwasher. Do not use liquid dish detergent for the dishwasher.Try running a load without dishes, using vinegar, or a bottle of Dishwasher Magic. Another possibility could be you're not getting enough water. The level should be close to the heater(check your tech sheet to be sure). The water temp should be at least 140 deg.F (no matter what the box says) Also, use a good brand of detergent (Cascade) and be sure your wetting Agent dispenser is full. (jet dry)You should not have to pre-wash your dishes..just scrape them well.The detergent actually needs some dirty dishes to work properly..fats, protien, etc. to make up 1 more chemical for the detergent.Another important step is to run the hot water faucet before running your d/w to "purge" the cold water out of the line.
Also check this links for some helpful information:-
http://www.appliance-repair-it.com/dishwasher-leaves-white-film-on-dishes.html
http://askville.amazon.com/dishwasher-washes-dishes-clean-white-residue-problem/AnswerViewer.do?requestId=6117170
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6192
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Aug 23, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
The dishwasher works fine but the jet dry doesn't seem to release to clear dishes. I have cleaned it out and put new liquid in. It always seems to be a the same level and never needs refill. Glasses are...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 02, 2011 | Maytag Dishwashers
My kitchenaid dishwasher leaves a white residue on clean dishes. 4 year old appliance, worked great until 6 months ago. under warranty, service repairman said i was using too much soap( am not). he cleaned...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Mar 10, 2011 | KitchenAid 24 in. KUDS01FLBL Built-in...
My dishes come out with a powdery coating on them and cutlery is not always clean. I use cascade and jet dry but this still does not help. Whyis this happening?
Hi
Daniel
Feb 20, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
GE TRITON dish washer. Utensils are stained after wash. I tried all that suggested solutions like cleaning with white vinegar, make sure hot water flows before it starts. I donot think we have hard water...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Jan 21, 2011 | Maytag Dishwasher
My dishes come out with cloudy film on them.
From Whirlpool:
*Film is due to either etching or silica film. Silica film is a milky, rainbow-colored deposit and etching is a cloudy film. Sometimes there is a water/chemical reaction with certain types of glassware.
o Silica film and etching are permanent and cannot be removed. Both can occur in any automatic dish washing machine and result from a water/chemical reaction with certain types of glassware. They are caused by some combination of:
+Soft or softened water.
+Alkaline washing solution.
+Insufficient rinsing.
+Dishwasher overloading.
+Heat of drying.
+Long/hot cycles.
To slow the down this process:
*Use a minimum amount of detergent but not less than 1 tablespoon per load.
*Use a liquid rinse aid.
*Under load the dishwasher to allow thorough rinsing.
*Do not use heated drying.
*Wash glasses by hand.
Do the following:
1. do you use a rinse agent
2. clean out the drain.
3. if you have a food disposal, run hot water through it and turn it on to clear it out before you turn on the dishwasher. The dishwasher drains into that sink. If you notice food or dirty water backing up into you sink when the dishwasher is draining, then the sink could have a minor clog and is backing up and being re-sprayed onto your dishes.
Source(s):
Use SANIVAC to clean lime deposits and extend the life of your dishwasher. If you have heavy water.
Run your dishwasher empty and pour in a cup of bleach and a cup of white vinegar to get the residue out.....run a regular cycle.......How hot is your hot water tank set on? The hotter the water the better a dishwasher washes and rinses, be careful it's not to hot as your shower and other sinks also will get this hot water......cut your dish soap down and make sure to use a Jet Rinse Aid. Again, be sure to use a liquid soap, and rinse agent, powders will cause a caustic reaction. Hope this helps. Let me know if there is anything else I can help you with.
JimmyC
Sep 30, 2009 | Bosch Dishwashers
Hi, We have a new whirlpool dishwasher type no. 575-0. GU2275X TVQO. We have not been able to get clean dishes since purchase. Water is hot, everything seems to be operating smoothly. Use the...
I think I can help. We have the same dishwasher and we have very hard water. The dry powder detergents don't work well. We have found Cascade All in One Gel detergent works best and we use only a little; don't go beyond the first mark in the detergent dispenser, regardless what the instructions say. We have found using more of any detergent makes white film. Don't fill up the pre-wash side either. The Cascade All in One Gel does both at one time, so no need to put some in the pre-wash side. Also keep Jet Dry in the rinse dispenser and make sure it is set up higher, turn the arrow to 4. Try that and move up if needed. Next, we put half a cup of white vinegar in the dishwasher, just pour it in the bottom each time, right before we wash the dishes. This works GREAT! We used the white vinegar in on our former dishwasher of 9 years and never had any trouble with any film buildup. The vinegar cuts all the film and makes glasses look terrific.
If you are still are having trouble, cut out the Heated Dry at then end. The heat can cake hard water on your dishes. It may not dry the dishes as well, but it seems to stop any buildup. Using the vinegar though, we use the Heated Dry and still have no film buildup. So for us, we use a small amount of Cascade All in One Gel detergent (buy this basic gel, no added anything), 1/2 cup white vinegar poured in the bottom and Jet Dry in the rinse dispenser. We always have sparkling clean dishes with no hard water buildup. If you don't have real hard water, but just a little hard water, you might try decreasing the white vinegar to 1/4 cup and increase it if you start seeing the white film build back up. Also don't overload the dishwasher. Make sure there is space in-between each dish and have all plates face toward the center.
Make sure you turn your sink faucet on to as hot as you can get it and run the water until it is hot, then turn off the faucet and turn on the dishwasher. This helps to keep the dishwasher from running longer, which would mean more hard water swishing around longer if you don't heat the water, and you know what that means, plus the heating element has to work harder to get the temp up and that makes it burn out quicker. Once a month check your jet sprays, that turn around in your dishwasher, because the little holes can stop up with hard water gunk and this will cause film on your dishes to build up. Take a toothpick and crush the gunk in any holes and make it go out of the holes. Hope this helps you!
Apr 27, 2009 | Dishwashers
Dishes have cloudy film on them
Try this. I want you to run your dishwasher empty, on the hottest water setting. Let it fill and just before it starts the wash cycle put in three cups of white vinegar. I expect your jets are clogged and the vinegar should hopefully open the jets back up. You don't need to add soap during this cleaning process. Works just like when you clean your coffee maker.
Apr 23, 2009 | GE Dishwashers
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dish Washer not cleaning
white film generally shows that there is not enough salt in the dishwasher, this is not normal salt like on your meal, you buy this from the detergent section of the store, add salt through the part where it says "S" unscrew the cap and put about 2 cups of it in, while filling with salt water will overflow out of the same place, this is normal this will start to work after about a wash or so if the salt is fine then check the heater on the machine, make sure its warming up etc if i have helped please rate me
Oct 03, 2007 | Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
76 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
